Saltar al contenido principal
Razer Blade 15 Advanced Model (Early 2020) SSD Replacement
Qué necesitas
  1. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Prepare your laptop for disassembly: paso 1, imagen 1 de 2 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Prepare your laptop for disassembly: paso 1, imagen 2 de 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Unfasten the back cover: paso 2, imagen 1 de 2 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Unfasten the back cover: paso 2, imagen 2 de 2
    • Use a T5 Torx driver to remove the ten 3.8 mm‑long screws securing the back cover.
  3. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Insert an opening pick: paso 3, imagen 1 de 3 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Insert an opening pick: paso 3, imagen 2 de 3 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Insert an opening pick: paso 3, imagen 3 de 3
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If it feels loose, remove it at any time.
    • Apply a suction handle to the middle of the back cover's right edge, between the lower rubber foot and the middle screws.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  4. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Angle the opening pick: paso 4, imagen 1 de 3 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Angle the opening pick: paso 4, imagen 2 de 3 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Angle the opening pick: paso 4, imagen 3 de 3
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
  5. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Free the bottom right corner: paso 5, imagen 1 de 3 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Free the bottom right corner: paso 5, imagen 2 de 3 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Free the bottom right corner: paso 5, imagen 3 de 3
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  6. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Free the front edge: paso 6, imagen 1 de 3 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Free the front edge: paso 6, imagen 2 de 3 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Free the front edge: paso 6, imagen 3 de 3
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame completely.
  7. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Remove the back cover: paso 7, imagen 1 de 3 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Remove the back cover: paso 7, imagen 2 de 3 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Remove the back cover: paso 7, imagen 3 de 3
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads.
  8. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Disconnect the battery: paso 8, imagen 1 de 3 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Disconnect the battery: paso 8, imagen 2 de 3 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Disconnect the battery: paso 8, imagen 3 de 3
    • Insert the point of a spudger under the middle of the battery connector's long edge.
    • Lift and disconnect the battery press connector from its socket on the motherboard.
    • This will require some force. Don't pry against any resistors or chips.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  9. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Unfasten the SSD: paso 9, imagen 1 de 2 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Unfasten the SSD: paso 9, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Use a Phillips screwdriver to remove the 3.8 mm‑long screw securing the SSD.
    • A sticker may cover the SSD screw. Pierce through it with your screwdriver or use tweezers to remove it.
    • With the screw removed, the SSD will pop up at a shallow angle.
  10. Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Remove the SSD: paso 10, imagen 1 de 2 Razer Blade 15 Advanced Model (Early 2020) SSD Replacement, Remove the SSD: paso 10, imagen 2 de 2
    • Pull the SSD straight out of its socket to remove it.
    • During reassembly, insert the SSD into its socket at a slight downward angle.
Conclusión
Spencer Day
Miembro Desde 09/14/22
95,649 Reputación
662 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 118
19,537 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 82
Todo El Tiempo: 1,281
