Saltar al contenido principal
Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement
Qué necesitas
  1. Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Prepare your laptop for disassembly: paso 1, imagen 1 de 2 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Prepare your laptop for disassembly: paso 1, imagen 2 de 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Unfasten the back cover: paso 2, imagen 1 de 2 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Unfasten the back cover: paso 2, imagen 2 de 2
    • Use a T5 Torx driver to remove the ten 3.8 mm‑long screws securing the back cover.
  3. Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Insert an opening pick: paso 3, imagen 1 de 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Insert an opening pick: paso 3, imagen 2 de 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Insert an opening pick: paso 3, imagen 3 de 3
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If it feels loose, remove it at any time.
    • Apply a suction handle to the middle of the back cover's right edge, between the lower rubber foot and the middle screws.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  4. Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Angle the opening pick: paso 4, imagen 1 de 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Angle the opening pick: paso 4, imagen 2 de 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Angle the opening pick: paso 4, imagen 3 de 3
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
  5. Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Free the bottom right corner: paso 5, imagen 1 de 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Free the bottom right corner: paso 5, imagen 2 de 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Free the bottom right corner: paso 5, imagen 3 de 3
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  6. Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Free the front edge: paso 6, imagen 1 de 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Free the front edge: paso 6, imagen 2 de 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Free the front edge: paso 6, imagen 3 de 3
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame completely.
  7. Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Remove the back cover: paso 7, imagen 1 de 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Remove the back cover: paso 7, imagen 2 de 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Remove the back cover: paso 7, imagen 3 de 3
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads.
  8. Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Disconnect the battery: paso 8, imagen 1 de 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Disconnect the battery: paso 8, imagen 2 de 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Disconnect the battery: paso 8, imagen 3 de 3
    • Insert the point of a spudger under the middle of the battery connector's long edge.
    • Lift and disconnect the battery press connector from its socket on the motherboard.
    • This will require some force. Don't pry against any resistors or chips.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  9. Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Reposition the cables: paso 9, imagen 1 de 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Reposition the cables: paso 9, imagen 2 de 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Reposition the cables: paso 9, imagen 3 de 3
    • The left fan will be on your right-hand side when working on the laptop, as it's laying upside down.
    • Use a spudger or your fingers to guide the Wi‑Fi card cables out of their clip on the top right corner of the fan.
    • Move the cables toward the right edge of the laptop and out of the way of the fan.
  10. Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Disconnect the left fan: paso 10, imagen 1 de 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Disconnect the left fan: paso 10, imagen 2 de 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Disconnect the left fan: paso 10, imagen 3 de 3
  11. Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Unfasten the left fan: paso 11, imagen 1 de 2 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Unfasten the left fan: paso 11, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Use a Phillips screwdriver to remove the two 5.3 mm‑long screws securing the left fan.
    • The fan screws may be covered with stickers. Pierce through them with your screwdriver or use tweezers to remove them.
  12. Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Remove the fan: paso 12, imagen 1 de 2 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Remove the fan: paso 12, imagen 2 de 2
    • Remove the left fan.
Conclusión
Una persona más ha completado esta guía.
Spencer Day
Miembro Desde 09/14/22
95,649 Reputación
662 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 118
19,537 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 27
Todo El Tiempo: 596
