Saltar al contenido principal
Razer Blackwidow Tournament Edition Chroma Front Panel Replacement
Qué necesitas
  1. Razer Blackwidow Tournament Edition Chroma Front Panel Replacement, Rubber Feet: paso 1, imagen 1 de 2 Razer Blackwidow Tournament Edition Chroma Front Panel Replacement, Rubber Feet: paso 1, imagen 2 de 2
    • Turn the keyboard over so that it is lying flat on its face.
    • Use the iFixit opening tool to pry the rubber feet off the keyboard.
  2. Razer Blackwidow Tournament Edition Chroma Front Panel Replacement, Front Panel: paso 2, imagen 1 de 2 Razer Blackwidow Tournament Edition Chroma Front Panel Replacement, Front Panel: paso 2, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
    • Use an opening tool as a wedge between the front and back panel to pry open the front panel.
    • If the front and back panel won't separate, DO NOT use excessive force. This may result in damaging the keyboard.
    • Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
    • Flip the keyboard over so the keys are facing up.
    • Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 21
Todo El Tiempo: 1,256
