Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard. Use an opening tool as a wedge between the front and back panel to pry open the front panel.
  • Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
  • Use an opening tool as a wedge between the front and back panel to pry open the front panel.
  • If the front and back panel won't separate, DO NOT use excessive force. This may result in damaging the keyboard.
  • Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
  • Flip the keyboard over so the keys are facing up.
  • Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
Insertar traducción aquí
