Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
RYDIS H68 Pro Wheel Replacement
Qué necesitas
    1. RYDIS H68 Pro Wheel  Replacement, Battery: paso 1, imagen 1 de 2 RYDIS H68 Pro Wheel  Replacement, Battery: paso 1, imagen 2 de 2
      • Flip the vacuum over so that the wheels are facing you.
      • Use a Phillips #1 screwdriver to remove the four 10 mm screws that surround the battery cover.
      Pregunta a FixBot
      Agregar Comentario
    2. RYDIS H68 Pro Wheel  Replacement: paso 2, imagen 1 de 1
      • Lift the battery cover up to reveal the battery.
      • Remove the battery.
      Pregunta a FixBot
      Agregar Comentario
    1. RYDIS H68 Pro Wheel  Replacement, Bumper: paso 3, imagen 1 de 3 RYDIS H68 Pro Wheel  Replacement, Bumper: paso 3, imagen 2 de 3 RYDIS H68 Pro Wheel  Replacement, Bumper: paso 3, imagen 3 de 3
      • Remove the eight 10 mm Phillips #1 screws.
      Pregunta a FixBot
      Agregar Comentario
    2. RYDIS H68 Pro Wheel  Replacement: paso 4, imagen 1 de 3 RYDIS H68 Pro Wheel  Replacement: paso 4, imagen 2 de 3 RYDIS H68 Pro Wheel  Replacement: paso 4, imagen 3 de 3
      • Hold the front bumper and pull it off.
      • It requires a lot of force to pull the bumper off.
      Pregunta a FixBot
      Agregar Comentario
    3. RYDIS H68 Pro Wheel  Replacement: paso 5, imagen 1 de 3 RYDIS H68 Pro Wheel  Replacement: paso 5, imagen 2 de 3 RYDIS H68 Pro Wheel  Replacement: paso 5, imagen 3 de 3
      • Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
      Pregunta a FixBot
      Agregar Comentario
    1. RYDIS H68 Pro Wheel  Replacement, Wheel assembly: paso 6, imagen 1 de 1
      • Remove three 10mm Philips #1 screws that are securing the wheel assembly.
      Pregunta a FixBot
      Agregar Comentario
    2. RYDIS H68 Pro Wheel  Replacement: paso 7, imagen 1 de 2 RYDIS H68 Pro Wheel  Replacement: paso 7, imagen 2 de 2
      • Remove the 10mm Phillips #1 screw securing the spring.
      • Then undo the spring from the plastic hook to completely remove it from the wheel assembly.
      Pregunta a FixBot
      Agregar Comentario
    3. RYDIS H68 Pro Wheel  Replacement: paso 8, imagen 1 de 3 RYDIS H68 Pro Wheel  Replacement: paso 8, imagen 2 de 3 RYDIS H68 Pro Wheel  Replacement: paso 8, imagen 3 de 3
      • Lift up on the plastic piece to remove the entire wheel assembly.
      Pregunta a FixBot
      Agregar Comentario
    4. RYDIS H68 Pro Wheel  Replacement: paso 9, imagen 1 de 3 RYDIS H68 Pro Wheel  Replacement: paso 9, imagen 2 de 3 RYDIS H68 Pro Wheel  Replacement: paso 9, imagen 3 de 3
      • Remove the plastic frame by pulling outward on the two spots where it is fastened.
      Pregunta a FixBot
      Agregar Comentario
    5. RYDIS H68 Pro Wheel  Replacement: paso 10, imagen 1 de 2 RYDIS H68 Pro Wheel  Replacement: paso 10, imagen 2 de 2
      • Remove the four 10mm Phillips #1 screws around the edges of the cover.
      Pregunta a FixBot
      Agregar Comentario
    6. RYDIS H68 Pro Wheel  Replacement: paso 11, imagen 1 de 3 RYDIS H68 Pro Wheel  Replacement: paso 11, imagen 2 de 3 RYDIS H68 Pro Wheel  Replacement: paso 11, imagen 3 de 3
      • Lift up on the top cover to remove it.
      • Removing the top cover reveals the gear system consisting of three gears.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Shawn O'Meara
Miembro Desde 02/27/17
101 Reputación
1 Guía escrita
Equipo
USFT-Lacy-S17S005G2 Miembro de USFT-Lacy-S17S005G2
Local Repair Groups
Miembros de 4
15 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 7
Ultimos 30 días: 31
Todo El Tiempo: 692
