Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Quick Antenna Connection Check for Delphi MyFi XM2GO
Qué necesitas
  1. Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery Cover: paso 1, imagen 1 de 3 Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery Cover: paso 1, imagen 2 de 3 Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery Cover: paso 1, imagen 3 de 3
    • Locate the large button on the top of the device.
    • Push down on the button and slide the cover away from the button.
    • The battery removal tab may pop up.
    Pregunta a FixBot
    Agregar Comentario
  2. Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery: paso 2, imagen 1 de 3 Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery: paso 2, imagen 2 de 3 Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery: paso 2, imagen 3 de 3
    • Grab the red pull tab and pull down to unlock the latch.
    • Pull the battery out.
    Pregunta a FixBot
    Agregar Comentario
  3. Quick Antenna Connection Check for Delphi MyFi XM2GO, Quick Antenna Connection Check for Delphi MyFi XM2GO: paso 3, imagen 1 de 1
    • Under the battery is a magnetic mat, shown in red, that shields battery interference with the reception of the XM Satellite antenna.
    • This mat is stuck to the back of the device like a sticker and can be removed.
    • CAUTION: Do not operate the device without this magnetic shield.
    Pregunta a FixBot
    Agregar Comentario
  4. Quick Antenna Connection Check for Delphi MyFi XM2GO: paso 4, imagen 1 de 3 Quick Antenna Connection Check for Delphi MyFi XM2GO: paso 4, imagen 2 de 3 Quick Antenna Connection Check for Delphi MyFi XM2GO: paso 4, imagen 3 de 3
    • On the bottom left side of the magnetic mat, the corner can be lifted up to reveal the U.FL antenna connector. A spudger or your fingernails can be used to pry up the corners.
    • These U.FL antenna connections are standard for most portable devices and WiFi cards. They may become detached through use and may be checked if no reception is present.
    • Lift up the corner and notice the two connectors going to the PCB.
    Pregunta a FixBot
    Agregar Comentario
  5. Quick Antenna Connection Check for Delphi MyFi XM2GO: paso 5, imagen 1 de 2 Quick Antenna Connection Check for Delphi MyFi XM2GO: paso 5, imagen 2 de 2
    • Both of these connectors must be firmly attached to the PCB. Try pressing them firmly to make sure they are making full contact.
    Pregunta a FixBot
    Agregar Comentario
  6. Quick Antenna Connection Check for Delphi MyFi XM2GO: paso 6, imagen 1 de 3 Quick Antenna Connection Check for Delphi MyFi XM2GO: paso 6, imagen 2 de 3 Quick Antenna Connection Check for Delphi MyFi XM2GO: paso 6, imagen 3 de 3
    • On the top right corner, the magnetic mat can be lifted up to check another U.FL connector as with the 3rd step.
    • This mat can be pressed down again to secure after checking the connector.
    Pregunta a FixBot
    Agregar Comentario
  7. Quick Antenna Connection Check for Delphi MyFi XM2GO: paso 7, imagen 1 de 1
    • Try pressing down on the U.FL connector, as seen in this picture, to ensure a secure connection.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Scott Byer
Miembro Desde 03/09/12
88 Reputación
5 Guías creadas
Equipo
Clemson, Team 1-2, Benson Spring 2012 Miembro de Clemson, Team 1-2, Benson Spring 2012
CLEM-BENSON-S12S1G2
Miembros de 3
18 Guías creadas
1Guía Comentario
la radio sigue sin funcionar
luis - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 37
Todo El Tiempo: 3,447
