Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
ProntoTec Axius Screen Replacement
Qué necesitas
    1. ProntoTec Axius Screen Replacement, Screen: paso 1, imagen 1 de 1
      • Make sure the device is completely turned off before you begin taking it apart to avoid risk of electrocution.
      • Place the tablet face-up on a flat table
      Pregunta a FixBot
      Agregar Comentario
    2. ProntoTec Axius Screen Replacement: paso 2, imagen 1 de 1
      • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
      • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
      Pregunta a FixBot
      Agregar Comentario
    3. ProntoTec Axius Screen Replacement: paso 3, imagen 1 de 1
      • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
      • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
      Pregunta a FixBot
      Agregar Comentario
    4. ProntoTec Axius Screen Replacement: paso 4, imagen 1 de 1
      • Remove all of the yellow tape that is on the device with the spudger.
      • Be careful not to cut any wires that are under the tapes.
      Pregunta a FixBot
      Agregar Comentario
    5. ProntoTec Axius Screen Replacement: paso 5, imagen 1 de 2 ProntoTec Axius Screen Replacement: paso 5, imagen 2 de 2
      • Use the flat end of the spudger to gently pry the battery from the back of the screen.
      Pregunta a FixBot
      Agregar Comentario
    6. ProntoTec Axius Screen Replacement: paso 6, imagen 1 de 2 ProntoTec Axius Screen Replacement: paso 6, imagen 2 de 2
      • Use a spudger to lift all the ribbon cable clamps
      • Detach all three ribbon cables from the clamps
      Pregunta a FixBot
      Agregar Comentario
    7. ProntoTec Axius Screen Replacement: paso 7, imagen 1 de 3 ProntoTec Axius Screen Replacement: paso 7, imagen 2 de 3 ProntoTec Axius Screen Replacement: paso 7, imagen 3 de 3
      • Using a Phillips screwdriver (PH00), unscrew the motherboard from the device
      Pregunta a FixBot
      Agregar Comentario
    8. ProntoTec Axius Screen Replacement: paso 8, imagen 1 de 3 ProntoTec Axius Screen Replacement: paso 8, imagen 2 de 3 ProntoTec Axius Screen Replacement: paso 8, imagen 3 de 3
      Herramienta utilizada en este paso:
      Heavy-Duty Spudger
      • Use the flat end of the metal spudger to remove the battery from the back of the screen of the device.
      • Avoid using metal when prying off the battery. For serious prying power, try using the heavy-duty plastic spudger.
      Pregunta a FixBot
      Agregar Comentario
    9. ProntoTec Axius Screen Replacement: paso 9, imagen 1 de 1
      • Remove the orange tab from the back of the screen as shown in the picture
      Pregunta a FixBot
      Agregar Comentario
    10. ProntoTec Axius Screen Replacement: paso 10, imagen 1 de 2 ProntoTec Axius Screen Replacement: paso 10, imagen 2 de 2
      • Use the flat end of the metal spudger to unclip and remove the screen from the casing.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Equipo
UMass Dartmouth, Team 5-3, Martin Fall 2016 Miembro de UMass Dartmouth, Team 5-3, Martin Fall 2016
UMASSD-MARTIN-F16S5G3
Miembros de 3
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 27
Todo El Tiempo: 603
