Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
ProScan PLT7223G Screen Replacement
Qué necesitas
    1. ProScan PLT7223G Screen Replacement, Screen: paso 1, imagen 1 de 1
      • Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
      Pregunta a FixBot
      Agregar Comentario
    2. ProScan PLT7223G Screen Replacement: paso 2, imagen 1 de 1
      • Use the blue plastic opening tool to pry open the tablet.
      • You will hear popping sounds. That's okay.
      • Be careful when using the blue plastic opening tool on the side of the device near the speakers, as there is a wire here that connects the speakers to the motherboard.
      Pregunta a FixBot
      Agregar Comentario
    3. ProScan PLT7223G Screen Replacement: paso 3, imagen 1 de 1
      • Remove three 4 mm screws from the motherboard.
      Pregunta a FixBot
      Agregar Comentario
    4. ProScan PLT7223G Screen Replacement: paso 4, imagen 1 de 1
      • Insert a spudger under the black tape that connects the silver wire to the interior of the front panel
      • Pull back the black tape with the spudger until it can be lifted up with your fingers.
      • Use your fingers to grab and lift the remainder of the black tape from device panel.
      Pregunta a FixBot
      Agregar Comentario
    5. ProScan PLT7223G Screen Replacement: paso 5, imagen 1 de 1
      • Use a plastic opening tool to push back the ZIF connector to release the ribbon wire on the motherboard.
      Pregunta a FixBot
      Agregar Comentario
    6. ProScan PLT7223G Screen Replacement: paso 6, imagen 1 de 1
      • Insert an opening tool underneath the silver base of the internal device element.
      • Use the opening tool to pry the element out of the case that holds the screen.
      • You will need to release a number of clips in order to remove the screen.
      • Be careful not to damage the motherboard or battery as you go.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
6 personas más completaron esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 27
Todo El Tiempo: 2,109
