Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
ProScan PLT7223G Front Facing Camera Replacement
Qué necesitas
    1. ProScan PLT7223G Front Facing Camera Replacement, Front Facing Camera: paso 1, imagen 1 de 1
      • Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
      Pregunta a FixBot
      Agregar Comentario
    2. ProScan PLT7223G Front Facing Camera Replacement: paso 2, imagen 1 de 1
      • Use the blue plastic opening tool to pry open the tablet.
      • You will hear popping sounds. That's okay.
      • Be careful when using the blue plastic opening tool on the side of the device near the speakers, as there is a wire here that connects the speakers to the motherboard.
      Pregunta a FixBot
      Agregar Comentario
    3. ProScan PLT7223G Front Facing Camera Replacement: paso 3, imagen 1 de 1
      • With a spudger, flip up the ZIF connector that connects the camera's ribbon cable to the motherboard. This will release the ribbon cable.
      Pregunta a FixBot
      Agregar Comentario
    4. ProScan PLT7223G Front Facing Camera Replacement: paso 4, imagen 1 de 1
      • Remove the black tape holding down the ribbon cable.
      Pregunta a FixBot
      Agregar Comentario
    5. ProScan PLT7223G Front Facing Camera Replacement: paso 5, imagen 1 de 1
      • Remove camera.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 16
Todo El Tiempo: 475
