Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Polaroid Automatic 100 Bottom Frame Spring Replacement
Qué necesitas
    1. Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: paso 1, imagen 1 de 3 Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: paso 1, imagen 2 de 3 Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: paso 1, imagen 3 de 3
      • Fully extend the bellows to prevent collapse using the #1 tab.
      • Remove the camera cover in order to make the camera easier to work with.
      • When collapsing bellows, press down on the metal frame above the bellows.
      Pregunta a FixBot
      Agregar Comentario
    2. Polaroid Automatic 100 Bottom Frame Spring Replacement: paso 2, imagen 1 de 1
      • Remove the Phillips #0 6mm screw on the shutter mount and the washers using a size 5 nut driver.
      Pregunta a FixBot
      Agregar Comentario
    3. Polaroid Automatic 100 Bottom Frame Spring Replacement: paso 3, imagen 1 de 1
      • Unscrew the 4.5 mm Phillips screw on the right with a Phillips #0 Screwdriver.
      Pregunta a FixBot
      Agregar Comentario
    4. Polaroid Automatic 100 Bottom Frame Spring Replacement: paso 4, imagen 1 de 3 Polaroid Automatic 100 Bottom Frame Spring Replacement: paso 4, imagen 2 de 3 Polaroid Automatic 100 Bottom Frame Spring Replacement: paso 4, imagen 3 de 3
      • Remove the spring from the shutter mount.
      • The hooks on the ends of the spring within the shutter mount may recoil when being removed, and may be sharp enough to puncture skin.
      • When reassembling, getting the smaller screw on the right hand side can be challenging. It may be helpful to tip the camera upside down so that gravity helps the screw fall into place.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Katie Miller
Miembro Desde 04/14/15
680 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 4-3, Maness Spring 2015 Miembro de Cal Poly, Team 4-3, Maness Spring 2015
CPSU-MANESS-S15S4G3
Miembros de 4
11 Guías creadas
2Guía Comentarios
Thank you so very much!!!
You saved my camera and my sanity!!!!
CAROL HOLDER - Contestar Compartir
Has anyone ever had to replace their bellows with a new one? If so, where do I get one from?
sbenite - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 10
Ultimos 30 días: 39
Todo El Tiempo: 1,576
