Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Playstation Controller Fast Fix
Qué necesitas
  1. Playstation Controller Fast Fix, Power Off and Disconnect: paso 1, imagen 1 de 1
    • Turn off the controller and disconnect it.
    Pregunta a FixBot
    Agregar Comentario
  2. Playstation Controller Fast Fix, Gather Tools: paso 2, imagen 1 de 1
    • Prepare tools including a precision screwdriver set, plastic pry tool, tweezers, isopropyl alcohol, and cotton swabs.
    Pregunta a FixBot
    Agregar Comentario
  3. Playstation Controller Fast Fix, Remove Outer Screws: paso 3, imagen 1 de 1
    • Locate and remove all screws from the controller casing using a screwdriver. top and bottom.
    Pregunta a FixBot
    Agregar Comentario
  4. Playstation Controller Fast Fix, Open the Controller Housing: paso 4, imagen 1 de 1
    • Carefully pry open the controller using a plastic tool to avoid damaging components.
    Pregunta a FixBot
    Agregar Comentario
  5. Playstation Controller Fast Fix, Disconnect Internal Components: paso 5, imagen 1 de 1
    • Gently detach the battery and ribbon cables to access the motherboard, and then unscrew the motherboard retainer(black cover)
    Pregunta a FixBot
    Agregar Comentario
  6. Playstation Controller Fast Fix, Locate the Analog Stick Module: paso 6, imagen 1 de 1
    • Identify the joystick assembly attached to the circuit board. Note: look hard for this one. It's a bit small
    Pregunta a FixBot
    Agregar Comentario
  7. Playstation Controller Fast Fix, Clean the Potentiometers: paso 7, imagen 1 de 1
    • Apply isopropyl alcohol to the base of the analog stick and rotate it to remove dirt and other stuff. Note: be careful on how hard you clean with the swabs, and don't apply too much rubbing alcohol.
    Pregunta a FixBot
    Agregar Comentario
  8. Playstation Controller Fast Fix, Reassemble and Test: paso 8, imagen 1 de 1
    • Reconnect all components, close the controller, and test it to ensure the stick drift is resolved. Note: since the battery was removed during the procedure, charging the controller is a must after putting it back together.
    Pregunta a FixBot
    Agregar Comentario
  9. Playstation Controller Fast Fix, Reassemble and Test: paso 9, imagen 1 de 1
    Pregunta a FixBot
    Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Aaron Ruiz
Miembro Desde 04/07/26
101 Reputación
1 Guía escrita
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 56
Ultimos 7 días: 242
Ultimos 30 días: 826
Todo El Tiempo: 2,136
