Introducción
This guide will walk you through step-by-step on how to properly remove and install the motherboard in the PlayStation 2 Slimline.
Qué necesitas
Paso 1 Removing Playstation 2 Slimline SCPH-7500x Outer Shell
Aviso: los pasos 1-7 provienen de una guía que está marcada como "En progreso".
Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
Paso 8 IR Sensor
Aviso: el paso 8 proviene de una guía que está marcada como "En progreso".
Herramienta utilizada en este paso:Tweezers$4.99-
Locate the IR sensor on the motherboard. Then, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard.
Paso 14 Optical Drive
Aviso: los pasos 14-18 provienen de una guía que está marcada como "En progreso".
Locate the optical drive on the motherboard.
What you see in this picture is the electronic components found in the PS2. We are now going to remove the top metal casing found on top of the motherboard.
12 personas más completaron esta guía.
