Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
PDP Rematch Advanced Back Buttons Replacement
Qué necesitas
  1. PDP Rematch Advanced Back Buttons Replacement, Joystick Cover: paso 1, imagen 1 de 3 PDP Rematch Advanced Back Buttons Replacement, Joystick Cover: paso 1, imagen 2 de 3 PDP Rematch Advanced Back Buttons Replacement, Joystick Cover: paso 1, imagen 3 de 3
    • Orient the controller so the back side is facing you.
    • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
    Pregunta a FixBot
    Agregar Comentario
  2. PDP Rematch Advanced Back Buttons Replacement: paso 2, imagen 1 de 3 PDP Rematch Advanced Back Buttons Replacement: paso 2, imagen 2 de 3 PDP Rematch Advanced Back Buttons Replacement: paso 2, imagen 3 de 3
    • Pull apart the controller's front and back shells with moderate force.
    • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
    Pregunta a FixBot
    Agregar Comentario
  3. PDP Rematch Advanced Back Buttons Replacement: paso 3, imagen 1 de 2 PDP Rematch Advanced Back Buttons Replacement: paso 3, imagen 2 de 2
    • Twist the thumbstick to remove it from the motherboard. Repeat this step if both thumbsticks need to be replaced.
    Pregunta a FixBot
    Agregar Comentario
  4. PDP Rematch Advanced Back Buttons Replacement, Back Shell: paso 4, imagen 1 de 2 PDP Rematch Advanced Back Buttons Replacement, Back Shell: paso 4, imagen 2 de 2
    • Grab the motor and pull away from the back shell. Repeat for both motors.
    Pregunta a FixBot
    Agregar Comentario
  5. PDP Rematch Advanced Back Buttons Replacement: paso 5, imagen 1 de 2 PDP Rematch Advanced Back Buttons Replacement: paso 5, imagen 2 de 2
    • Use a Phillips #00 Screwdriver to remove the two 5mm screws from the motherboard.
    Pregunta a FixBot
    Agregar Comentario
  6. PDP Rematch Advanced Back Buttons Replacement: paso 6, imagen 1 de 3 PDP Rematch Advanced Back Buttons Replacement: paso 6, imagen 2 de 3 PDP Rematch Advanced Back Buttons Replacement: paso 6, imagen 3 de 3
    • Remove the motherboard from the back shell using moderate force.
    Pregunta a FixBot
    Agregar Comentario
  7. PDP Rematch Advanced Back Buttons Replacement, Back Buttons: paso 7, imagen 1 de 2 PDP Rematch Advanced Back Buttons Replacement, Back Buttons: paso 7, imagen 2 de 2
    • Use a Phillips #00 to remove the two 5mm screws from the back buttons.
    Pregunta a FixBot
    Agregar Comentario
  8. PDP Rematch Advanced Back Buttons Replacement: paso 8, imagen 1 de 3 PDP Rematch Advanced Back Buttons Replacement: paso 8, imagen 2 de 3 PDP Rematch Advanced Back Buttons Replacement: paso 8, imagen 3 de 3
    • Lift the back button, and then pull it out through the back shell. Do this for both back buttons.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Collin Lawe
Miembro Desde 10/02/23
462 Reputación
3 Guías creadas
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 36
Todo El Tiempo: 695
