Introducción
Running over rocks or hard pieces of debris can cause deep or wide scratches that create unwanted friction between the board and the snow. Gouges that are too large to be filled in with a normal wax job will need to be patched with a plastic filler known as P-Tex.
If the gouge is deep enough that the core material is exposed, you should bring these repairs to a snowboard shop.
Qué necesitas
Release the binding straps by lifting up on the buckle and pulling towards the direction of the end of the ladder.
Turn the snowboard over so the bottom of the board is facing up.
Set the snowboard down on a stable work surface so that it does not rock or move.
Assess the damage. If there are loose strands of material around the hole, slice them off carefully with a razor blade.
Remove any extra wax with a metal scraper.
Use 150 grit sandpaper to roughen up the inside of the gouge.
When the P-Tex is smooth and flush with the base, your repair is finished. Take a couple of seconds to admire your work.
Wax your board before use.
2 personas más completaron esta guía.
