Introducción
Opening the grinder in a Siemens Surpresso Compact.
Qué necesitas
Remove the water container, the brew group and the drip tray with pomace container.
Using a spoon, remove as much of the coffee beans as possible from the coffee bean container.
Press with a flat-head screwdriver into the openings on the side with the water tank. This releases the latches on the top.
Press the flat-head screwdriver into the opening on the side with the brew group. This will release the last notch on the top.
Lift the top off.
On some models, a cable leads to the sensor on the powder tray. Unplug the connector on this cable first.
The grinder is situated on the top right rearside of the device. The adjuster and the outer ring can just be taken off, but this is only necessary if the grinder has to be completely replaced. Be careful and do not use excessive force.
The following pictures show a grinder of a Jura and there are slight differences. But since the grinder is the same, the repair is basically the same.
Una persona más ha completado esta guía.
Un agradecimiento especial a estos traductores:
100%
¡ VauWeh nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
