Saltar al contenido principal
One Education Infinity:One Motherboard Replacement
Qué necesitas
  1. One Education Infinity:One Motherboard Replacement, Battery: paso 1, imagen 1 de 2 One Education Infinity:One Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
  2. One Education Infinity:One Motherboard Replacement: paso 2, imagen 1 de 3 One Education Infinity:One Motherboard Replacement: paso 2, imagen 2 de 3 One Education Infinity:One Motherboard Replacement: paso 2, imagen 3 de 3
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
  3. One Education Infinity:One Motherboard Replacement: paso 3, imagen 1 de 3 One Education Infinity:One Motherboard Replacement: paso 3, imagen 2 de 3 One Education Infinity:One Motherboard Replacement: paso 3, imagen 3 de 3
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
  4. One Education Infinity:One Motherboard Replacement: paso 4, imagen 1 de 1
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
  5. One Education Infinity:One Motherboard Replacement, Antenna: paso 5, imagen 1 de 2 One Education Infinity:One Motherboard Replacement, Antenna: paso 5, imagen 2 de 2
    • Use ESD safe tweezers to disconnect the antenna from the motherboard.
  6. One Education Infinity:One Motherboard Replacement, Motherboard: paso 6, imagen 1 de 3 One Education Infinity:One Motherboard Replacement, Motherboard: paso 6, imagen 2 de 3 One Education Infinity:One Motherboard Replacement, Motherboard: paso 6, imagen 3 de 3
    • Use a spudger to flip up the black flap on the camera's ZIF connector.
    • Pull the ribbon cable straight out of the connector.
  7. One Education Infinity:One Motherboard Replacement: paso 7, imagen 1 de 1
    • Use tweezers to pull the dock connection cable away from the motherboard.
  8. One Education Infinity:One Motherboard Replacement: paso 8, imagen 1 de 1
    • Use a Phillips #00 screwdriver to unscrew the two 3.4 mm screws.
    • Use a Phillips #000 screwdriver to unscrew the one 4.2mm screw.
  9. One Education Infinity:One Motherboard Replacement: paso 9, imagen 1 de 1
    • Lift the protective shield away from the motherboard.
  10. One Education Infinity:One Motherboard Replacement: paso 10, imagen 1 de 3 One Education Infinity:One Motherboard Replacement: paso 10, imagen 2 de 3 One Education Infinity:One Motherboard Replacement: paso 10, imagen 3 de 3
    • With the flat end of a spudger, flip up the black flap on the display's ZIF connector.
    • Insert the pointed end of the spudger between the cable and the motherboard and gently pull the cable straight out of the connector.
    • During reassembly, be sure to insert the cable into the connector up to the white line on the cable and then close the retaining flap.
  11. One Education Infinity:One Motherboard Replacement: paso 11, imagen 1 de 1
    • Gently lift the motherboard away from the display assembly.
Conclusión
Una persona más ha completado esta guía.
Taylor Bratsch
Miembro Desde 09/06/16
5,742 Reputación
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 489
