Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Oculus Rift Development Kit 2 Display Screen Replacement
Qué necesitas
  1. Oculus Rift Development Kit 2 Display Screen Replacement, Eye Relief Adjustment Screw: paso 1, imagen 1 de 3 Oculus Rift Development Kit 2 Display Screen Replacement, Eye Relief Adjustment Screw: paso 1, imagen 2 de 3 Oculus Rift Development Kit 2 Display Screen Replacement, Eye Relief Adjustment Screw: paso 1, imagen 3 de 3
    • Remove front cover plate.
    • Unplug the USB and HDMI cables from the Oculus Rift DK2.
    Pregunta a FixBot
    Agregar Comentario
  2. Oculus Rift Development Kit 2 Display Screen Replacement: paso 2, imagen 1 de 3 Oculus Rift Development Kit 2 Display Screen Replacement: paso 2, imagen 2 de 3 Oculus Rift Development Kit 2 Display Screen Replacement: paso 2, imagen 3 de 3
    • Remove the four 3/8" Phillips #0 screws from the inner portion of the headset.
    Pregunta a FixBot
    Agregar Comentario
  3. Oculus Rift Development Kit 2 Display Screen Replacement: paso 3, imagen 1 de 2 Oculus Rift Development Kit 2 Display Screen Replacement: paso 3, imagen 2 de 2
    • With the screws removed, gently pull the headband frame apart from the headset.
    Pregunta a FixBot
    Agregar Comentario
  4. Oculus Rift Development Kit 2 Display Screen Replacement, Remove Lens: paso 4, imagen 1 de 2 Oculus Rift Development Kit 2 Display Screen Replacement, Remove Lens: paso 4, imagen 2 de 2
    • With the Oculus facing up, twist the right lens clockwise and lift it out. Repeat for the left lens twisting counterclockwise instead.
    Pregunta a FixBot
    Agregar Comentario
  5. Oculus Rift Development Kit 2 Display Screen Replacement, Headset Motherboard: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Using tweezers, carefully lift the four rubber plugs as shown. They are a bit snug and you may need to jiggle them free with the tweezers.
    Pregunta a FixBot
    Agregar Comentario
  6. Oculus Rift Development Kit 2 Display Screen Replacement: paso 6, imagen 1 de 1
    • Remove the four 3/8" screws attaching the eyewear enclosure to the front casing.
    • Read the next step before removing the faceplate!
    Pregunta a FixBot
    Agregar Comentario
  7. Oculus Rift Development Kit 2 Display Screen Replacement: paso 7, imagen 1 de 2 Oculus Rift Development Kit 2 Display Screen Replacement: paso 7, imagen 2 de 2
    • Carefully separate the faceplate and the cover. Gently rest the cover plate on top of the faceplate as shown in the pictures.
    • Do not use excessive force when separating these two pieces. There is a delicate ribbon cable connected to each.
    Pregunta a FixBot
    Agregar Comentario
  8. Oculus Rift Development Kit 2 Display Screen Replacement: paso 8, imagen 1 de 2 Oculus Rift Development Kit 2 Display Screen Replacement: paso 8, imagen 2 de 2
    • Gently pull out the small side tabs on the ribbon cable connector as shown to release the cable.
    • Push the tabs away from you, with the headset oriented as pictured. Carefully slide the ribbon cable out.
    • The headset should now be two separate pieces.
    Pregunta a FixBot
    Agregar Comentario
  9. Oculus Rift Development Kit 2 Display Screen Replacement: paso 9, imagen 1 de 3 Oculus Rift Development Kit 2 Display Screen Replacement: paso 9, imagen 2 de 3 Oculus Rift Development Kit 2 Display Screen Replacement: paso 9, imagen 3 de 3
    • Unscrew the three 1/4" Phillips #00 screws as pictured and use the tweezers to lift them out.
    Pregunta a FixBot
    Agregar Comentario
  10. Oculus Rift Development Kit 2 Display Screen Replacement: paso 10, imagen 1 de 1
    • Lift the tape and gently pry up the video data ribbon cable using the plastic opening tool as shown.
    Pregunta a FixBot
    Agregar Comentario
  11. Oculus Rift Development Kit 2 Display Screen Replacement: paso 11, imagen 1 de 3 Oculus Rift Development Kit 2 Display Screen Replacement: paso 11, imagen 2 de 3 Oculus Rift Development Kit 2 Display Screen Replacement: paso 11, imagen 3 de 3
    • Gently pry back the motherboard clips to release the motherboard. The motherboard should now lift free.
    Pregunta a FixBot
    Agregar Comentario
  12. Oculus Rift Development Kit 2 Display Screen Replacement, Display Screen: paso 12, imagen 1 de 3 Oculus Rift Development Kit 2 Display Screen Replacement, Display Screen: paso 12, imagen 2 de 3 Oculus Rift Development Kit 2 Display Screen Replacement, Display Screen: paso 12, imagen 3 de 3
    • Remove the six 1/4" Phillips #1 screws as shown. There should be two on each short side, and one on each long side.
    • Gently lift the plastic screen holder and display screen away from the remaining piece of the faceplate.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
4 personas más completaron esta guía.
Adam
Miembro Desde 01/20/15
661 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 18-5, Maness Winter 2015 Miembro de Cal Poly, Team 18-5, Maness Winter 2015
CPSU-MANESS-W15S18G5
Miembros de 4
6 Guías creadas
2Guía Comentarios
It's possible to use the Samsung Galaxy Note 4 screen?
Lauro Adriano Freitas - Contestar Compartir
moldovancasyan19 - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 32
Todo El Tiempo: 3,293
