Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Nook Color Display Replacement
Qué necesitas
  1. Nook Color Display Replacement, Back Cover: paso 1, imagen 1 de 2 Nook Color Display Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
    Pregunta a FixBot
    Agregar Comentario
  2. Nook Color Display Replacement: paso 2, imagen 1 de 2 Nook Color Display Replacement: paso 2, imagen 2 de 2
    • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
    Pregunta a FixBot
    Agregar Comentario
  3. Nook Color Display Replacement, Front Cover: paso 3, imagen 1 de 1
    • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
    Pregunta a FixBot
    Agregar Comentario
  4. Nook Color Display Replacement: paso 4, imagen 1 de 2 Nook Color Display Replacement: paso 4, imagen 2 de 2
    • Pry off the front panel using the plastic opening tool.
    Pregunta a FixBot
    Agregar Comentario
  5. Nook Color Display Replacement: paso 5, imagen 1 de 2 Nook Color Display Replacement: paso 5, imagen 2 de 2
    • Lift up on the connectors to disconnect them using the plastic opening tool.
    Pregunta a FixBot
    Agregar Comentario
  6. Nook Color Display Replacement, Motherboard: paso 6, imagen 1 de 3 Nook Color Display Replacement, Motherboard: paso 6, imagen 2 de 3 Nook Color Display Replacement, Motherboard: paso 6, imagen 3 de 3
    • Gently lift and peel the orange and grey ribbon connectors to disconnect the screen and motherboard.
    Pregunta a FixBot
    Agregar Comentario
  7. Nook Color Display Replacement: paso 7, imagen 1 de 1
    • Remove the easy-to-miss T5 Torx 3.8 mm screw located in the tabbed corner of the device.
    Pregunta a FixBot
    Agregar Comentario
  8. Nook Color Display Replacement: paso 8, imagen 1 de 2 Nook Color Display Replacement: paso 8, imagen 2 de 2
    • Lift the motherboard gently from the side with the larger connector ribbon.
    • Slide the white cable gently from underneath its holding place to free the motherboard completely.
    • Remove the motherboard carefully from the device.
    Pregunta a FixBot
    Agregar Comentario
  9. Nook Color Display Replacement, Display: paso 9, imagen 1 de 3 Nook Color Display Replacement, Display: paso 9, imagen 2 de 3 Nook Color Display Replacement, Display: paso 9, imagen 3 de 3
    • Use a plastic opening tool to gently pry the display upwards.
    • Lift the display out with your hands until the display has separated from the frame.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
7 personas más completaron esta guía.
Equipo
USF Tampa, Team 11-5, Blackwell Winter 2015 Miembro de USF Tampa, Team 11-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G5
Miembros de 3
14 Guías creadas
1Guía Comentario
this site doesn't sell the Nook Color display. Where did you get yours?
Suzette Garoutte - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 54
Todo El Tiempo: 4,378
