Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Nook Color Buttons Replacement
Qué necesitas
  1. Nook Color Buttons Replacement, Back Cover: paso 1, imagen 1 de 2 Nook Color Buttons Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
    Pregunta a FixBot
    Agregar Comentario
  2. Nook Color Buttons Replacement: paso 2, imagen 1 de 2 Nook Color Buttons Replacement: paso 2, imagen 2 de 2
    • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
    Pregunta a FixBot
    Agregar Comentario
  3. Nook Color Buttons Replacement, Front Cover: paso 3, imagen 1 de 1
    • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
    Pregunta a FixBot
    Agregar Comentario
  4. Nook Color Buttons Replacement: paso 4, imagen 1 de 2 Nook Color Buttons Replacement: paso 4, imagen 2 de 2
    • Pry off the front panel using the plastic opening tool.
    Pregunta a FixBot
    Agregar Comentario
  5. Nook Color Buttons Replacement: paso 5, imagen 1 de 2 Nook Color Buttons Replacement: paso 5, imagen 2 de 2
    • Lift up on the connectors to disconnect them using the plastic opening tool.
    Pregunta a FixBot
    Agregar Comentario
  6. Nook Color Buttons Replacement, Buttons: paso 6, imagen 1 de 3 Nook Color Buttons Replacement, Buttons: paso 6, imagen 2 de 3 Nook Color Buttons Replacement, Buttons: paso 6, imagen 3 de 3
    • Once you have removed both the back and front panels of the device, you will isolate the panel which contains the buttons. You will remove the volume buttons on the top right first. Use some force upwards and the button will slide free.
    Pregunta a FixBot
    Agregar Comentario
  7. Nook Color Buttons Replacement: paso 7, imagen 1 de 3 Nook Color Buttons Replacement: paso 7, imagen 2 de 3 Nook Color Buttons Replacement: paso 7, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Next, you will remove the power button from the top left of the middle portion of your device. Using tweezers you will carefully lift the button from where it sits and remove it.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
2 personas más completaron esta guía.
John Goly
Miembro Desde 01/20/15
529 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 11-5, Blackwell Winter 2015 Miembro de USF Tampa, Team 11-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G5
Miembros de 3
14 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 30
Todo El Tiempo: 1,178
