Introducción
Use this guide to replace the eyepiece cover that allows for focus compensation.
Herramientas
Partes
No se especificaron partes.
Use your finger tip to pull the battery release tab toward the center of the D70.
Open the battery door and rotate it away from the bottom cover.
Remove the following eight screws securing the bottom cover to the D70:
Six 5.8 mm Phillips screws
One 10.7 mm Phillips screws
One 8.2 mm Phillips screws
Remove the two 4.8 mm Phillips screws securing the battery side of the rear cover to the D70.
Use a plastic opening tool to carefully pry up the flash unit at the point shown in the picture.
Remove the 5.7 mm Phillips screw in the top corner of the battery compartment.
Remove the silver Phillips screw securing the port cover to the side of the D70.
Remove the port cover from the D70.
Touch the bare leads of a capacitor discharge tool to the pink and blue capacitor leads soldered to the circuit board near the AF lamp.
At this point, the capacitor should be discharged. Avoid touching the bare leads to prevent a shock if the capacitor is still partially charged.
5 personas más completaron esta guía.
Un Comentario
Eyepiece Remove/Instal Step 32. To remove or replace the eyepiece, the diopter adjustment slider should be pushed fully to the '-' setting; that is, towards the base of the camera.
