Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 3
Carefully de-solder the black, grey, white, and orange leads (boxed in red) from the side of the circuit board near the AF lamp. Lightly heat the joint of each lead with a soldering iron as you apply slight tension to the wire with a pair of tweezers. Do not excessively heat the board. Also, be sure not to accidentally melt the plastic case with the side of the soldering iron.
  • Carefully de-solder the black, grey, white, and orange leads (boxed in red) from the side of the circuit board near the AF lamp.
  • Lightly heat the joint of each lead with a soldering iron as you apply slight tension to the wire with a pair of tweezers.
  • Do not excessively heat the board. Also, be sure not to accidentally melt the plastic case with the side of the soldering iron.
  • Repeat the process until all four leads are de-soldered.
Insertar traducción aquí
