Saltar al contenido principal
Nest x Yale Lock Motherboard Replacement
Qué necesitas
  1. Nest x Yale Lock Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • Before proceeding, make sure the batteries are removed to avoid being electrocuted and damage to the lock
    • If you do not know how to remove the batteries then I would recommend looking at our battery replacement guide for help.
  2. Nest x Yale Lock Motherboard Replacement: paso 2, imagen 1 de 2 Nest x Yale Lock Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove 3 screws as shown to remove the first cover.
    • The 3 screws are 0.25 inches length
  3. Nest x Yale Lock Motherboard Replacement: paso 3, imagen 1 de 1
    • Using a pin to push down the knot holding the wire and the tweezer to safely remove the wire from the motherboard
  4. Nest x Yale Lock Motherboard Replacement: paso 4, imagen 1 de 2 Nest x Yale Lock Motherboard Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use a spudger or plastic tool to lift the ZIF lock upward (as shown in the first picture).
    • Use tweezers to remove the ribbon cable from the motherboard.
  5. Nest x Yale Lock Motherboard Replacement: paso 5, imagen 1 de 1
    • Continue to remove 2 screws holding the motherboard to the lock shell.
    • The screws are 0.20 inches in length.
  6. Nest x Yale Lock Motherboard Replacement: paso 6, imagen 1 de 2 Nest x Yale Lock Motherboard Replacement: paso 6, imagen 2 de 2
    • Use an opening tool to push the motherboard out as shown in the picture.
Conclusión
Bryant Duong
Miembro Desde 09/26/22
379 Reputación
2 Guías creadas
Equipo
CSU Los Angeles, Team 5-3, Adachi Fall 2022 Miembro de CSU Los Angeles, Team 5-3, Adachi Fall 2022
CSULA-ADACHI-F22S5G3
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 12
Ultimos 30 días: 29
Todo El Tiempo: 446
