Saltar al contenido principal
Nest x Yale Lock Battery Replacement
Qué necesitas
  1. Nest x Yale Lock Battery Replacement, Battery: paso 1, imagen 1 de 2 Nest x Yale Lock Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure to insert a thin-metal pin into the hole on top and press it down until you feel the cover is loose and then take it out.
  2. Nest x Yale Lock Battery Replacement: paso 2, imagen 1 de 1
    • Once you take out the cover pry the batteries out, then replace them and ensure that the batteries are aligned correctly.
  3. Nest x Yale Lock Battery Replacement: paso 3, imagen 1 de 1
    • Once the batteries are put in correctly, you can put the cover back on and it should be working.
Conclusión
Bryant Duong
Miembro Desde 09/26/22
379 Reputación
2 Guías creadas
Equipo
CSU Los Angeles, Team 5-3, Adachi Fall 2022 Miembro de CSU Los Angeles, Team 5-3, Adachi Fall 2022
CSULA-ADACHI-F22S5G3
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 42
Ultimos 30 días: 200
Todo El Tiempo: 2,805
