Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Nerf Vortex Vigilon Loading Spring Replacement
Qué necesitas
  1. Nerf Vortex Vigilon Loading Spring Replacement, Removing the slide screws: paso 1, imagen 1 de 1
    • The two slide pieces hold the orange sight in place. Expect that the sight will come off when you remove the slide pieces.
    • Using a screwdriver, carefully unscrew the three #00 1 cm Phillips screws holding the two slide pieces together.
    • Both sides of the slide will come off when the screws are removed.
    Pregunta a FixBot
    Agregar Comentario
  2. Nerf Vortex Vigilon Loading Spring Replacement, Removing the slide pieces: paso 2, imagen 1 de 1
    • Lift both slide pieces off of the gun.
    Pregunta a FixBot
    Agregar Comentario
  3. Nerf Vortex Vigilon Loading Spring Replacement, Removing the outer screws: paso 3, imagen 1 de 2 Nerf Vortex Vigilon Loading Spring Replacement, Removing the outer screws: paso 3, imagen 2 de 2
    • Remove the twelve #00 1 cm Phillips screws.
    • Because the holes for the screws are deeper than the screw size, some of the screws may not come out even after you have completely unscrewed them. They will come out when you take off the outside cover in the next step, which is okay.
    • Rotate the gun so that the front is facing you to remove the final screw.
    Pregunta a FixBot
    Agregar Comentario
  4. Nerf Vortex Vigilon Loading Spring Replacement, Removing the outside cover: paso 4, imagen 1 de 1
    • When removing the cover, the clip attachment and the spring will likely fall out of the gun.
    • Lift the outside cover off of the gun. Only the side where you removed the screws will come off.
    • The magazine will slide down automatically as you remove the cover.
    Pregunta a FixBot
    Agregar Comentario
  5. Nerf Vortex Vigilon Loading Spring Replacement, Removing the spring: paso 5, imagen 1 de 2 Nerf Vortex Vigilon Loading Spring Replacement, Removing the spring: paso 5, imagen 2 de 2
    • Lift the spring out towards you.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Cara Pew
Miembro Desde 09/29/14
932 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 13-6, Forte Fall 2014 Miembro de Cal Poly, Team 13-6, Forte Fall 2014
CPSU-FORTE-F14S13G6
Miembros de 5
7 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 34
Todo El Tiempo: 1,902
