Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Microsoft Kinect Case Replacement
Qué necesitas
    1. Microsoft Kinect Case Replacement, Case: paso 1, imagen 1 de 3 Microsoft Kinect Case Replacement, Case: paso 1, imagen 2 de 3 Microsoft Kinect Case Replacement, Case: paso 1, imagen 3 de 3
      • Remove the two plastic strips off the bottom of the main Kinect housing using the metal spudger's sharper side.
      • Peel off the two Xbox 360 stickers from the bottom of the case to reveal two hidden screws.
      • Some force may be required to remove the adhesive. Applying heat to the adhesive may make it easier to remove.
      • Do not overheat as it may cause damage to the internal components.
      Pregunta a FixBot
      Agregar Comentario
    2. Microsoft Kinect Case Replacement: paso 2, imagen 1 de 1
      • Unscrew the six 12mm T10 Torx screws.
      Pregunta a FixBot
      Agregar Comentario
    3. Microsoft Kinect Case Replacement: paso 3, imagen 1 de 3 Microsoft Kinect Case Replacement: paso 3, imagen 2 de 3 Microsoft Kinect Case Replacement: paso 3, imagen 3 de 3
      • Remove the top portion of the case from the rest of the body.
      • Detach the side portions of the case from the body.
      • Remove the fan piece from the side of the body. Unplug it from the logic board to fully remove it.
      • When unplugging the fan, be sure to pull from the white connector at the end of the wire to avoid breaking it.
      Pregunta a FixBot
      Agregar Comentario
    4. Microsoft Kinect Case Replacement: paso 4, imagen 1 de 1
      • Remove the bottom portion of the case by sliding it out from under the body.
      • The bottom of the case may be difficult to remove if there is any residual adhesive. If the residual adhesive prevents you from removing the case, apply gentle heat and wiggle the case out.
      Pregunta a FixBot
      Agregar Comentario
    5. Microsoft Kinect Case Replacement: paso 5, imagen 1 de 2 Microsoft Kinect Case Replacement: paso 5, imagen 2 de 2
      • Remove the four 7mm T10 Torx screws (two on each side of the metal body).
      Pregunta a FixBot
      Agregar Comentario
    6. Microsoft Kinect Case Replacement: paso 6, imagen 1 de 2 Microsoft Kinect Case Replacement: paso 6, imagen 2 de 2
      • Remove the front portion of the case containing the lens coverings for the cameras.
      • The LED component is connected to the front portion of the case. To disconnect it, just pull it out of its plastic connector.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
4 personas más completaron esta guía.
Sumi Kime
Miembro Desde 04/22/15
234 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 14-7, Amido Spring 2015 Miembro de Cal Poly, Team 14-7, Amido Spring 2015
CPSU-AMIDO-S15S14G7
Miembros de 4
67 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 20
Ultimos 30 días: 96
Todo El Tiempo: 2,445
