Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Micro-USB Port Replacement
Qué necesitas
    1. Micro-USB Port Replacement, Back Plate: paso 1, imagen 1 de 2 Micro-USB Port Replacement, Back Plate: paso 1, imagen 2 de 2
      • Unscrew the four 3.4 mm flat head screws
      Pregunta a FixBot
      Agregar Comentario
    2. Micro-USB Port Replacement: paso 2, imagen 1 de 1
      • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
      Pregunta a FixBot
      Agregar Comentario
    1. Micro-USB Port Replacement, Lithium Battery: paso 3, imagen 1 de 1
      • If not replacing lithium battery, skip down two steps.
      • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
      Pregunta a FixBot
      Agregar Comentario
    2. Micro-USB Port Replacement: paso 4, imagen 1 de 1
      • Desolder the battery connections from the motherboard. Learn how to solder components here!
      Pregunta a FixBot
      Agregar Comentario
    1. Micro-USB Port Replacement, Motherboard: paso 5, imagen 1 de 1
      • Use PH00 screw driver to remove two 2.4mm Phillips head screws.
      Pregunta a FixBot
      Agregar Comentario
    2. Micro-USB Port Replacement: paso 6, imagen 1 de 1
      Herramienta utilizada en este paso:
      • Use a spudger or tweezers to remove a white sticker that covers a Phillips head screw.
      Pregunta a FixBot
      Agregar Comentario
    3. Micro-USB Port Replacement: paso 7, imagen 1 de 1
      • Use PH00 screwdriver to remove 5.2mm Phillips head screw
      Pregunta a FixBot
      Agregar Comentario
    4. Micro-USB Port Replacement: paso 8, imagen 1 de 3 Micro-USB Port Replacement: paso 8, imagen 2 de 3 Micro-USB Port Replacement: paso 8, imagen 3 de 3
      • Use ESD safe tweezers to remove the gold ribbon cable.
      • This will expose a second 5.2mm Phillips head screw that can be removed with a PH00 screwdriver.
      Pregunta a FixBot
      Agregar Comentario
    5. Micro-USB Port Replacement: paso 9, imagen 1 de 2 Micro-USB Port Replacement: paso 9, imagen 2 de 2
      • Use a spudger to gently pry on the motherboard towards the top of the watch, being towards the 12 o'clock position to loosen the motherboard.
      • You can now access the parts and pieces on the bottom of, and below the motherboard.
      Pregunta a FixBot
      Agregar Comentario
    1. Micro-USB Port Replacement, Micro-USB Port: paso 10, imagen 1 de 1
      • Locate the four main soldering points marked in red.
      • Be aware of the five additional soldered pins marked by the blue arrow.
      Pregunta a FixBot
      Agregar Comentario
    2. Micro-USB Port Replacement: paso 11, imagen 1 de 3 Micro-USB Port Replacement: paso 11, imagen 2 de 3 Micro-USB Port Replacement: paso 11, imagen 3 de 3
      • Begin to desolder the points pointed out in the last step.
      • Use the soldering wick to help remove the solder.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Equipo
IUPUI, Team 3-3, Baechle Fall 2016 Miembro de IUPUI, Team 3-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G3
Miembros de 4
8 Guías creadas
1Guía Comentario
I want to know that what I have to do if want to replace the lithium battery with usb direct powered device.
amupis232389 - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 21
Ultimos 30 días: 70
Todo El Tiempo: 18,348
