Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Merch Source Projector Entertainment II Light Bulb Replacement
Qué necesitas
    1. Merch Source Projector Entertainment II Light Bulb Replacement, Outer Casing: paso 1, imagen 1 de 2 Merch Source Projector Entertainment II Light Bulb Replacement, Outer Casing: paso 1, imagen 2 de 2
      • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
      Pregunta a FixBot
      Agregar Comentario
    2. Merch Source Projector Entertainment II Light Bulb Replacement: paso 2, imagen 1 de 1
      • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
      • The bottom right panel screw does not come completely out the panel door.
      Pregunta a FixBot
      Agregar Comentario
    3. Merch Source Projector Entertainment II Light Bulb Replacement: paso 3, imagen 1 de 2 Merch Source Projector Entertainment II Light Bulb Replacement: paso 3, imagen 2 de 2
      • Using your hands, gently pry the top and bottom of the projector casing apart.
      Pregunta a FixBot
      Agregar Comentario
    1. Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: paso 4, imagen 1 de 3 Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: paso 4, imagen 2 de 3 Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: paso 4, imagen 3 de 3
      • Remove the light bulb from its housing unit.
      • Do not damage the 2 white cables leading into the light bulb panel.
      Pregunta a FixBot
      Agregar Comentario
    2. Merch Source Projector Entertainment II Light Bulb Replacement, Replace light bulb: paso 5, imagen 1 de 2 Merch Source Projector Entertainment II Light Bulb Replacement, Replace light bulb: paso 5, imagen 2 de 2
      • Remove the light bulb from the door panel by gently wiggling it back and forth. Do not twist the light bulb.
      • The light blub is held into the socket with prongs, and should easily pull straight out.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Stephanie
Miembro Desde 01/08/15
282 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 18-3, Maness Winter 2015 Miembro de Cal Poly, Team 18-3, Maness Winter 2015
CPSU-MANESS-W15S18G3
Miembros de 3
8 Guías creadas
1Guía Comentario
Mi nuevo proyector no prende la luz ni el ventilador al conectarlo al tomacorriente y encenderlo.
JAVIER MUNOZ - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 11
Ultimos 30 días: 39
Todo El Tiempo: 2,651
