Remove the water tank and drainage tray.
Remove the side cover and remove the brewing unit.
Remove all coffee beans.
Press carefully into the slits on the sides using a minus screwdriver or a flat metal spatula, to release the clasps on the upper surface. These may be well tight and you have to use some force.
You should have created a separation between the upper surface and side panels. Now lever the upper covering away using a plastic tool. This may be quite stuck and you may apply some force.
The drainage valve is exposed.
Remove the spring on the lower end of the valve.
Lift the upper gray part of the valve. Push the lower part of the valve a little bit downwards und lift it out.
Pull the cap of the grey upper valve body. Use pliers, if it is stuck.
There are two gaskets, the flat side pointing outwards.
Plunger and downholder
Piston and spring
Replace the gaskets and reassemble the valve.
Una persona más ha completado esta guía.
Un agradecimiento especial a estos traductores:
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
