Introducción
Usa esta guía para reemplazar un cable AirPort/Bluetooth roto.
Qué necesitas
Extrae los siguientes diez tornillos:
Tres tornillos Phillips #00 de 14.4 mm
Tres tornillos Phillips #00 de 3.5 mm
Cuatro tornillos de resalto Phillips #00 de 3.5 mm
Usa el borde de un spudger para levantar el conector de la batería haciendo palanca para extraer su toma de corriente de la placa madre.
Usa el extremo plano de un spudger para levantar el conector AirPort/Bluetooth de su zócalo en la placa lógica.
Para volver a ensamblar tu dispositivo, sigue estas instrucciones en orden inverso.
38 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
¡ Francisco Javier Saiz Esteban nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
3 comentarios
Had the most strange errors with a wi-fi with errors for long. Send the computer both to apple and to insurance without success.
Now I'm on my own on my wifi first broke saying "No hardware installed", Bluetooth was still working in the beginning thou. After checking here I ordered a new cable and everything was fixed in under 30 minutes.
The cable I bought was names -A in the end instead of -02 but everything works just fine so far. According to the seller they are the same. Thanks for help solving this strange problem in a simple way!
I've just made this and all my connectivity problems are now gone!
Thanks iFixit team :)
Fixed my wifi connectivity problems! However it did not fix my bluetooth connection. I did have a problem where the wire was actually disconnected from the actual connection and the connection was stuck in the socket. I got the connection out by using an Xacto blade on the side to pry it out. Then I followed all the other steps and it worked fine! I also disconnected the battery and had no problems reconnecting it.
