Introducción
Having issues with your MacBook recognizing your brand new SATA hard drive? The problem could lie in the hard drive connector, the link between the drive and the logic board.
Qué necesitas
Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
Remove the following 3 screws:
One 11 mm Phillips #00 in the middle of the case.
Two 14.5 mm Phillips #00.
Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
Use the white plastic pull-tab to slide the hard drive to the left and out of the computer.
Carefully lift the hard drive connector out of the case slightly, and turn it over to reveal the IR sensor connector beneath. Use a spudger to flip up the tiny bar holding the cable in place.
Slide the orange IR sensor cable out of its connector, and lift the hard drive connector out of the computer.
26 personas más completaron esta guía.
