Saltar al contenido principal
MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement
Qué necesitas
  1. MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement, Lower Case: paso 1, imagen 1 de 1
    Herramienta utilizada en este paso:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Comprar
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement: paso 2, imagen 1 de 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement, Battery Connector: paso 3, imagen 1 de 2 MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement, Battery Connector: paso 3, imagen 2 de 2
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  4. MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: paso 4, imagen 1 de 2 MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: paso 4, imagen 2 de 2
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
  5. MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement: paso 5, imagen 1 de 1
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  6. MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement: paso 6, imagen 1 de 2 MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement: paso 6, imagen 2 de 2
    • Slightly lift the free end of the AirPort/Bluetooth card and pull it out of its socket on the logic board.
    • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
    • Remove the AirPort/Bluetooth card from the Air.
Conclusión
9 personas más completaron esta guía.
Adam O'Camb
Miembro Desde 04/11/15
199,413 Reputación
416 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 50
Ultimos 30 días: 193
Todo El Tiempo: 9,896
