Introducción
Use this guide to replace the fan in a 2018 MacBook Air.
Qué necesitas
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.1 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case.
Peel back the tape covering the battery connector enough to reveal the connector underneath.
Slide the tip of a spudger underneath the speaker cable and pry straight up to disconnect the speaker.
Use a T3 Torx driver to remove the three 1.4 mm screws securing the audio board cable bracket.
Remove the cable bracket.
Remove the following screws:
Two 4.3 mm, T5 Torx screws
One 2.4 mm, T3 Torx screw
Slide an opening pick under the audio board cable to slice through the adhesive securing it to the fan.
Use a T5 Torx driver to remove the three 2.7 mm screws securing the fan.
3 personas más completaron esta guía.
