Saltar al contenido principal
Mac mini (2024) CMOS Battery Replacement
Qué necesitas
  1. Mac mini (2024) CMOS Battery Replacement, Before you begin: paso 1, imagen 1 de 2 Mac mini (2024) CMOS Battery Replacement, Before you begin: paso 1, imagen 2 de 2
    • Fully shut down your Mac mini and unplug all cables from it.
    • Flip over your Mac mini and place it on a clean, flat surface to avoid scratching the chassis.
  2. Mac mini (2024) CMOS Battery Replacement, Create a gap: paso 2, imagen 1 de 3 Mac mini (2024) CMOS Battery Replacement, Create a gap: paso 2, imagen 2 de 3 Mac mini (2024) CMOS Battery Replacement, Create a gap: paso 2, imagen 3 de 3
    • Insert a Jimmy into the gap between the bottom cover and the chassis.
    • Pry up the bottom cover to create a gap.
    • Keep the Jimmy inserted under the bottom cover.
  3. Mac mini (2024) CMOS Battery Replacement, Insert an opening pick: paso 3, imagen 1 de 3 Mac mini (2024) CMOS Battery Replacement, Insert an opening pick: paso 3, imagen 2 de 3 Mac mini (2024) CMOS Battery Replacement, Insert an opening pick: paso 3, imagen 3 de 3
    • Insert an opening pick into the gap created by the Jimmy.
    • Remove the Jimmy.
  4. Mac mini (2024) CMOS Battery Replacement, Release the clips: paso 4, imagen 1 de 3 Mac mini (2024) CMOS Battery Replacement, Release the clips: paso 4, imagen 2 de 3 Mac mini (2024) CMOS Battery Replacement, Release the clips: paso 4, imagen 3 de 3
    • Slide the opening pick along the bottom cover until you feel it snag on a clip.
    • There are four clips total—one at each corner of the bottom cover.
    • Twist the pick to lift the clip out of its slot.
  5. Mac mini (2024) CMOS Battery Replacement: paso 5, imagen 1 de 3 Mac mini (2024) CMOS Battery Replacement: paso 5, imagen 2 de 3 Mac mini (2024) CMOS Battery Replacement: paso 5, imagen 3 de 3
    • Continue sliding and prying with the pick along the perimeter of the bottom cover to release the remaining clips.
    • Don't insert the pick more than an inch when sliding near the power button, as you risk damaging the cable.
    • During reassembly, press along the perimeter of the bottom until you hear and feel all four clips click back into place.
  6. Mac mini (2024) CMOS Battery Replacement: paso 6, imagen 1 de 2 Mac mini (2024) CMOS Battery Replacement: paso 6, imagen 2 de 2
    • Don't remove the bottom cover yet, as it's still connected to the Mac mini with a cable.
    • Lift the edge of the bottom cover opposite the power button and flip it over to expose the power button cable.
  7. Mac mini (2024) CMOS Battery Replacement, Disconnect the power button: paso 7, imagen 1 de 3 Mac mini (2024) CMOS Battery Replacement, Disconnect the power button: paso 7, imagen 2 de 3 Mac mini (2024) CMOS Battery Replacement, Disconnect the power button: paso 7, imagen 3 de 3
    • Grip the power button cable close to the head and pull it away from its socket to disconnect it.
  8. Mac mini (2024) CMOS Battery Replacement, Remove the bottom cover: paso 8, imagen 1 de 1
    • Remove the bottom cover.
  9. Mac mini (2024) CMOS Battery Replacement, Remove the CMOS battery screws: paso 9, imagen 1 de 2 Mac mini (2024) CMOS Battery Replacement, Remove the CMOS battery screws: paso 9, imagen 2 de 2
    Herramienta utilizada en este paso:
    FixMat
    $36.95
    • While the Mac mini uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP screwdriver to remove the two 2.1 mm‑long screws securing the CMOS battery screws.
  10. Mac mini (2024) CMOS Battery Replacement, Remove the CMOS battery: paso 10, imagen 1 de 2 Mac mini (2024) CMOS Battery Replacement, Remove the CMOS battery: paso 10, imagen 2 de 2
    • Lift the CMOS battery and its housing off the inner plate and remove it.
  11. Mac mini (2024) CMOS Battery Replacement, Separate the CMOS battery: paso 11, imagen 1 de 3 Mac mini (2024) CMOS Battery Replacement, Separate the CMOS battery: paso 11, imagen 2 de 3 Mac mini (2024) CMOS Battery Replacement, Separate the CMOS battery: paso 11, imagen 3 de 3
    • Use the flat end of a spudger, or your fingernail, to lift the CMOS battery out of its housing.
    • During reassembly, place the flat, shinier side of the battery into the section of the housing with the plus sign.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Mac mini (2024) Answers Community for help.
Alex Diaz-Kokaisl
Miembro Desde 01/16/22
162,476 Reputación
769 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
118 Miembros
19,455 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 77
Ultimos 30 días: 262
Todo El Tiempo: 707
