Introducción
Use this guide to replace a noisy worn-out fan.
Herramientas
Partes
Place your thumbs in the depressions cut into the bottom cover.
Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
17 personas más completaron esta guía.
Un Comentario
How do you know the order of the wires when placing the 4 wires back onto the motherboard?
