Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Logitech Webcam Pro 9000 USB Connection Replacement
Qué necesitas
  1. Logitech Webcam Pro 9000 USB Connection Replacement, Front and Back Cover: paso 1, imagen 1 de 2 Logitech Webcam Pro 9000 USB Connection Replacement, Front and Back Cover: paso 1, imagen 2 de 2
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
    Pregunta a FixBot
    Agregar Comentario
  2. Logitech Webcam Pro 9000 USB Connection Replacement: paso 2, imagen 1 de 2 Logitech Webcam Pro 9000 USB Connection Replacement: paso 2, imagen 2 de 2
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
    Pregunta a FixBot
    Agregar Comentario
  3. Logitech Webcam Pro 9000 USB Connection Replacement, USB Connection: paso 3, imagen 1 de 2 Logitech Webcam Pro 9000 USB Connection Replacement, USB Connection: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Use tweezers to grasp the white wire connector on the back of the motherboard.
    • Wiggle the connector back and forth to remove it from the socket.
    Pregunta a FixBot
    Agregar Comentario
  4. Logitech Webcam Pro 9000 USB Connection Replacement: paso 4, imagen 1 de 2 Logitech Webcam Pro 9000 USB Connection Replacement: paso 4, imagen 2 de 2
    • Desolder the joint on the front of the motherboard to completely detach the USB cable.
    • Follow this link to learn how to properly solder and desolder your parts.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Cory Davis
Miembro Desde 04/14/13
236 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 12-34, Amido Spring 2013 Miembro de Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
Miembros de 4
16 Guías creadas
1Guía Comentario
what is the connector called
Anirudh Krishnan - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 29
Todo El Tiempo: 2,497
