Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Levoit Core 300-RAC Control Board Replacement
Qué necesitas
    1. Levoit Core 300-RAC Control Board Replacement, Control Board: paso 1, imagen 1 de 3 Levoit Core 300-RAC Control Board Replacement, Control Board: paso 1, imagen 2 de 3 Levoit Core 300-RAC Control Board Replacement, Control Board: paso 1, imagen 3 de 3
      • Make sure the device is turned off and unplugged before disassembling it.
      • Insert the Jimmy between the gray grille cover and the top of the device.
      • Work your way around the grille cover with the Jimmy to release the clips holding it in place.
      • Take note of the placement of the clips, as they are keyed and need to go back in the exact way they came out.
      • Remove the grille cover gently as it is connected by a ribbon cable.
      • Be careful not to put too much strain on the ribbon cable as it may break.
      Pregunta a FixBot
      Agregar Comentario
    2. Levoit Core 300-RAC Control Board Replacement: paso 2, imagen 1 de 3 Levoit Core 300-RAC Control Board Replacement: paso 2, imagen 2 de 3 Levoit Core 300-RAC Control Board Replacement: paso 2, imagen 3 de 3
      • Squeeze the tab on the connector to release the bundled cable from the control board.
      • The connector should come out fairly easily, so do not force it. Pulling too hard could damage the connector.
      Pregunta a FixBot
      Agregar Comentario
    3. Levoit Core 300-RAC Control Board Replacement: paso 3, imagen 1 de 2 Levoit Core 300-RAC Control Board Replacement: paso 3, imagen 2 de 2
      • Gently bend the gray plastic cover to release the control board.
      • There are several hard tabs holding the control board in place.
      Pregunta a FixBot
      Agregar Comentario
    4. Levoit Core 300-RAC Control Board Replacement: paso 4, imagen 1 de 3 Levoit Core 300-RAC Control Board Replacement: paso 4, imagen 2 de 3 Levoit Core 300-RAC Control Board Replacement: paso 4, imagen 3 de 3
      • Lift the control board from the gray plastic cover.
      • Take note of the orientations of the buttons, as that will help during reassembly.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Mustafa
Miembro Desde 11/03/23
259 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 1-6, Petersen Fall 2023 Miembro de UMass Dartmouth, Team 1-6, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G6
Miembros de 5
8 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 30
Ultimos 30 días: 98
Todo El Tiempo: 1,893
