Saltar al contenido principal
Lenovo Yoga 900-13ISK Battery Replacement
Qué necesitas
  1. Lenovo Yoga 900-13ISK Battery Replacement, Back Cover: paso 1, imagen 1 de 2 Lenovo Yoga 900-13ISK Battery Replacement, Back Cover: paso 1, imagen 2 de 2
    • Using a T5 Torx screwdriver, remove the ten 5.5 mm screws from the back case of the laptop.
  2. Lenovo Yoga 900-13ISK Battery Replacement: paso 2, imagen 1 de 3 Lenovo Yoga 900-13ISK Battery Replacement: paso 2, imagen 2 de 3 Lenovo Yoga 900-13ISK Battery Replacement: paso 2, imagen 3 de 3
    • Use a spudger to pry open the back case at the hinges of the laptop.
    • There are plastic clips around the perimeter of the case holding down the back cover. These will need to be popped off as the cover is removed.
    • Use your fingers to completely pop off the back cover.
  3. Lenovo Yoga 900-13ISK Battery Replacement, Battery: paso 3, imagen 1 de 3 Lenovo Yoga 900-13ISK Battery Replacement, Battery: paso 3, imagen 2 de 3 Lenovo Yoga 900-13ISK Battery Replacement, Battery: paso 3, imagen 3 de 3
    • Remove the five 3.6 mm screws from the battery with a Phillips #00 screwdriver.
  4. Lenovo Yoga 900-13ISK Battery Replacement: paso 4, imagen 1 de 3 Lenovo Yoga 900-13ISK Battery Replacement: paso 4, imagen 2 de 3 Lenovo Yoga 900-13ISK Battery Replacement: paso 4, imagen 3 de 3
    • Grab the bottom corners of the battery and gently pull the battery until the cable disconnects from the connector on the motherboard.
    • While reassembling, use a plastic spudger to push the battery cable into the connector on the underside of the motherboard. This will be easier to do before the screws are replaced.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
Una persona más ha completado esta guía.
Austin Blakely
Miembro Desde 03/11/19
19,649 Reputación
53 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,430 Guías creadas
Un comentario
Phillips 00 will not fit the 5 screws in my computer!
Elaine Gelb - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 17
Ultimos 7 días: 25
Ultimos 30 días: 68
Todo El Tiempo: 2,719
