Saltar al contenido principal
Lenovo Thinkpad T450 Internal Battery Replacement
Qué necesitas
  1. Lenovo Thinkpad T450 Internal Battery Replacement, External Battery: paso 1, imagen 1 de 3 Lenovo Thinkpad T450 Internal Battery Replacement, External Battery: paso 1, imagen 2 de 3 Lenovo Thinkpad T450 Internal Battery Replacement, External Battery: paso 1, imagen 3 de 3
    • Using your hands, slide the two locking tabs away from each other to release the battery.
    • Slide the battery up and out of the device.
  2. Lenovo Thinkpad T450 Internal Battery Replacement, Back Cover: paso 2, imagen 1 de 1
    • Using the JIS #00 screwdriver, unscrew seven screws from the back cover.
    • These screws are not removable and will remain in the back cover.
    • Use the JIS #00 screwdriver to remove the single 2.8 mm screw from the back cover.
  3. Lenovo Thinkpad T450 Internal Battery Replacement: paso 3, imagen 1 de 3 Lenovo Thinkpad T450 Internal Battery Replacement: paso 3, imagen 2 de 3 Lenovo Thinkpad T450 Internal Battery Replacement: paso 3, imagen 3 de 3
    • Insert a plastic opening tool into the edges of the laptop and work your way around the edges to pry off the back cover from the device.
    • Remove the back cover from the device.
  4. Lenovo Thinkpad T450 Internal Battery Replacement, Internal Battery: paso 4, imagen 1 de 2 Lenovo Thinkpad T450 Internal Battery Replacement, Internal Battery: paso 4, imagen 2 de 2
    • Using the JIS #00 screwdriver, remove the three 2.8 mm screws.
  5. Lenovo Thinkpad T450 Internal Battery Replacement: paso 5, imagen 1 de 2 Lenovo Thinkpad T450 Internal Battery Replacement: paso 5, imagen 2 de 2
    • Disconnect the battery cable from the motherboard using the plastic opening tool.
  6. Lenovo Thinkpad T450 Internal Battery Replacement: paso 6, imagen 1 de 1
    • Lift up and remove the battery from the device.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
2 personas más completaron esta guía.
Justin Ogihara
Miembro Desde 09/18/17
27,253 Reputación
52 Guías creadas
Equipo
EDU Team Miembro de EDU Team
Staff
7 Miembros
640 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 20
Ultimos 30 días: 142
Todo El Tiempo: 4,419
