Saltar al contenido principal
Lenovo ThinkPad T480s SSD Replacement
Qué necesitas
  1. Lenovo ThinkPad T480s SSD Replacement, Bottom Cover: paso 1, imagen 1 de 2 Lenovo ThinkPad T480s SSD Replacement, Bottom Cover: paso 1, imagen 2 de 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s SSD Replacement: paso 2, imagen 1 de 3 Lenovo ThinkPad T480s SSD Replacement: paso 2, imagen 2 de 3 Lenovo ThinkPad T480s SSD Replacement: paso 2, imagen 3 de 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s SSD Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad T480s SSD Replacement: paso 3, imagen 2 de 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s SSD Replacement, Battery: paso 4, imagen 1 de 2 Lenovo ThinkPad T480s SSD Replacement, Battery: paso 4, imagen 2 de 2
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s SSD Replacement: paso 5, imagen 1 de 3 Lenovo ThinkPad T480s SSD Replacement: paso 5, imagen 2 de 3 Lenovo ThinkPad T480s SSD Replacement: paso 5, imagen 3 de 3
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s SSD Replacement, SSD: paso 6, imagen 1 de 2 Lenovo ThinkPad T480s SSD Replacement, SSD: paso 6, imagen 2 de 2
    • Use the Phillips #1 screwdriver to remove one 2.8 mm screw securing the SSD.
  7. Lenovo ThinkPad T480s SSD Replacement: paso 7, imagen 1 de 3 Lenovo ThinkPad T480s SSD Replacement: paso 7, imagen 2 de 3 Lenovo ThinkPad T480s SSD Replacement: paso 7, imagen 3 de 3
    • Pull the SSD out of the socket.
Conclusión
Sarah Westberg
Miembro Desde 03/11/19
29,324 Reputación
71 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
118 Miembros
19,446 Guías creadas
2 comentarios
Is there a need to remove the battery?
Sanjay - Contestar
Hi Sanjay, we just want to make sure that there is no power to the system and the step to remove the battery is included as a precaution. Typically, you could detach the connector from the motherboard without removing the battery, and that would be sufficient. This connector is integrated into the battery case so we recommend battery removal. Thanks!
Sarah Westberg -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 18
Ultimos 30 días: 71
Todo El Tiempo: 3,342
