Saltar al contenido principal
Lenovo ThinkPad T480s RAM Replacement
Qué necesitas
  1. Lenovo ThinkPad T480s RAM Replacement, Bottom Cover: paso 1, imagen 1 de 2 Lenovo ThinkPad T480s RAM Replacement, Bottom Cover: paso 1, imagen 2 de 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s RAM Replacement: paso 2, imagen 1 de 3 Lenovo ThinkPad T480s RAM Replacement: paso 2, imagen 2 de 3 Lenovo ThinkPad T480s RAM Replacement: paso 2, imagen 3 de 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s RAM Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad T480s RAM Replacement: paso 3, imagen 2 de 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s RAM Replacement, RAM: paso 4, imagen 1 de 3 Lenovo ThinkPad T480s RAM Replacement, RAM: paso 4, imagen 2 de 3 Lenovo ThinkPad T480s RAM Replacement, RAM: paso 4, imagen 3 de 3
    • Pull the plastic film back.
    • Push the clips outward to release the RAM stick.
    • My device doesn't have RAM so you don't see it.
    • The RAM stick will pop out at an angle. Pull the RAM stick out at the same angle.
Conclusión
Sarah Westberg
Miembro Desde 03/11/19
24,055 Reputación
71 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
141 Miembros
17,854 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 26
Ultimos 30 días: 119
Todo El Tiempo: 4,078
