Saltar al contenido principal
Lenovo ThinkPad T480s Hall Sensor Replacement
Qué necesitas
  1. Lenovo ThinkPad T480s Hall Sensor Replacement, Bottom Cover: paso 1, imagen 1 de 2 Lenovo ThinkPad T480s Hall Sensor Replacement, Bottom Cover: paso 1, imagen 2 de 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Hall Sensor Replacement: paso 2, imagen 1 de 3 Lenovo ThinkPad T480s Hall Sensor Replacement: paso 2, imagen 2 de 3 Lenovo ThinkPad T480s Hall Sensor Replacement: paso 2, imagen 3 de 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Hall Sensor Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad T480s Hall Sensor Replacement: paso 3, imagen 2 de 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Hall Sensor Replacement, Battery: paso 4, imagen 1 de 2 Lenovo ThinkPad T480s Hall Sensor Replacement, Battery: paso 4, imagen 2 de 2
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s Hall Sensor Replacement: paso 5, imagen 1 de 3 Lenovo ThinkPad T480s Hall Sensor Replacement: paso 5, imagen 2 de 3 Lenovo ThinkPad T480s Hall Sensor Replacement: paso 5, imagen 3 de 3
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: paso 6, imagen 1 de 3 Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: paso 6, imagen 2 de 3 Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: paso 6, imagen 3 de 3
    • Use a spudger to disconnect the cable from the Hall sensor.
  7. Lenovo ThinkPad T480s Hall Sensor Replacement: paso 7, imagen 1 de 2 Lenovo ThinkPad T480s Hall Sensor Replacement: paso 7, imagen 2 de 2
    • With the Phillips #1 screwdriver, remove one 3.1 mm screw from the sensor.
  8. Lenovo ThinkPad T480s Hall Sensor Replacement: paso 8, imagen 1 de 3 Lenovo ThinkPad T480s Hall Sensor Replacement: paso 8, imagen 2 de 3 Lenovo ThinkPad T480s Hall Sensor Replacement: paso 8, imagen 3 de 3
    • Remove the sensor from the system.
Conclusión
Sarah Westberg
Miembro Desde 03/11/19
24,106 Reputación
71 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
141 Miembros
17,895 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 24
Ultimos 30 días: 117
Todo El Tiempo: 2,574
