Introducción
Use this guide to replace the antenna kit in your Lenovo ThinkPad T480s laptop..
The antenna kit includes the WWAN and WLAN replacement cables and antennas. Some signs of a faulty or failed antenna kit include low performing Wi-Fi signal or no signal at all.
If your antenna kit has started to fail, and you are no longer receiving a strong signal it may be time to replace the antenna kit. Before attempting an antenna kit replacement, you may be able to resolve the issue using Lenovo’s troubleshooting guide.
Before attempting to replace the antenna kit, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
Qué necesitas
Use the spudger to disconnect the coaxial cables from the Wi-Fi card and WWAN card.
Using the spudger, pry the LCD bezel up from the edges starting near the hinges.
Use the spudger to remove the internal bezel.
Start at the corner by the hinge and lift the edge of the internal bezel up with the pointed end of the spudger.
Hold the internal bezel with your fingers and work your way around the perimeter of the screen carefully pulling the bezel up.
Remove four 2.9 mm screws from the LCD panel using the Phillips #1 screwdriver.
Use the Phillips #1 screwdriver to remove two 2.8 mm screws from the hinge in the upper right corner.
