Saltar al contenido principal
Lenovo ThinkPad T470 RAM Replacement
Qué necesitas
  1. Lenovo ThinkPad T470 RAM Replacement, External Battery: paso 1, imagen 1 de 3 Lenovo ThinkPad T470 RAM Replacement, External Battery: paso 1, imagen 2 de 3 Lenovo ThinkPad T470 RAM Replacement, External Battery: paso 1, imagen 3 de 3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T470 RAM Replacement: paso 2, imagen 1 de 3 Lenovo ThinkPad T470 RAM Replacement: paso 2, imagen 2 de 3 Lenovo ThinkPad T470 RAM Replacement: paso 2, imagen 3 de 3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 RAM Replacement, Bottom Cover: paso 3, imagen 1 de 2 Lenovo ThinkPad T470 RAM Replacement, Bottom Cover: paso 3, imagen 2 de 2
    • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
  4. Lenovo ThinkPad T470 RAM Replacement: paso 4, imagen 1 de 3 Lenovo ThinkPad T470 RAM Replacement: paso 4, imagen 2 de 3 Lenovo ThinkPad T470 RAM Replacement: paso 4, imagen 3 de 3
    • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
    • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
    • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
    • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
  5. Lenovo ThinkPad T470 RAM Replacement: paso 5, imagen 1 de 1
    • Remove the bottom cover from the laptop.
    • Disconnect the battery from the board before continuing.
  6. Lenovo ThinkPad T470 RAM Replacement, RAM: paso 6, imagen 1 de 3 Lenovo ThinkPad T470 RAM Replacement, RAM: paso 6, imagen 2 de 3 Lenovo ThinkPad T470 RAM Replacement, RAM: paso 6, imagen 3 de 3
    • Use your fingers to flip the black flap covering the top stick of RAM down.
  7. Lenovo ThinkPad T470 RAM Replacement: paso 7, imagen 1 de 2 Lenovo ThinkPad T470 RAM Replacement: paso 7, imagen 2 de 2
    • Use your fingers to push the metal clips on either end of the RAM outwards.
    • The RAM will pop up by a few millimeters.
  8. Lenovo ThinkPad T470 RAM Replacement: paso 8, imagen 1 de 2 Lenovo ThinkPad T470 RAM Replacement: paso 8, imagen 2 de 2
    • Use your fingers to lift the RAM out of its socket and away from the laptop to remove it.
  9. Lenovo ThinkPad T470 RAM Replacement: paso 9, imagen 1 de 2 Lenovo ThinkPad T470 RAM Replacement: paso 9, imagen 2 de 2
    • Use your fingers to flip the black flap covering the bottom stick of RAM up.
    • Use your thumbs to push the metal clips on either end of the RAM outwards.
  10. Lenovo ThinkPad T470 RAM Replacement: paso 10, imagen 1 de 2 Lenovo ThinkPad T470 RAM Replacement: paso 10, imagen 2 de 2
    • The RAM will pop up slightly.
  11. Lenovo ThinkPad T470 RAM Replacement: paso 11, imagen 1 de 2 Lenovo ThinkPad T470 RAM Replacement: paso 11, imagen 2 de 2
Conclusión
Una persona más ha completado esta guía.
Kristen Gismondi
Miembro Desde 11/12/14
82,707 Reputación
202 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,430 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 61
Ultimos 30 días: 232
Todo El Tiempo: 9,148
