Saltar al contenido principal
Lenovo ThinkPad T470 Bottom Cover Replacement
Qué necesitas
  1. Lenovo ThinkPad T470 Bottom Cover Replacement, External Battery: paso 1, imagen 1 de 3 Lenovo ThinkPad T470 Bottom Cover Replacement, External Battery: paso 1, imagen 2 de 3 Lenovo ThinkPad T470 Bottom Cover Replacement, External Battery: paso 1, imagen 3 de 3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T470 Bottom Cover Replacement: paso 2, imagen 1 de 3 Lenovo ThinkPad T470 Bottom Cover Replacement: paso 2, imagen 2 de 3 Lenovo ThinkPad T470 Bottom Cover Replacement: paso 2, imagen 3 de 3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 Bottom Cover Replacement, Bottom Cover: paso 3, imagen 1 de 2 Lenovo ThinkPad T470 Bottom Cover Replacement, Bottom Cover: paso 3, imagen 2 de 2
    • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
  4. Lenovo ThinkPad T470 Bottom Cover Replacement: paso 4, imagen 1 de 3 Lenovo ThinkPad T470 Bottom Cover Replacement: paso 4, imagen 2 de 3 Lenovo ThinkPad T470 Bottom Cover Replacement: paso 4, imagen 3 de 3
    • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
    • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
    • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
    • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
  5. Lenovo ThinkPad T470 Bottom Cover Replacement: paso 5, imagen 1 de 1
    • Remove the bottom cover from the laptop.
    • Disconnect the battery from the board before continuing.
Conclusión
2 personas más completaron esta guía.
Kristen Gismondi
Miembro Desde 11/12/14
92,246 Reputación
241 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 118
19,526 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 19
Ultimos 30 días: 98
Todo El Tiempo: 3,723
