Introducción
Use this guide to replace the fan and heat sink in a Lenovo ThinkPad T460 laptop.
The heat sink transfers heat from the laptop’s CPU to the fan, which redirects the heat away from the laptop’s internal components. The fan and heat sink work together to prevent the laptop from overheating, which can cause damage to the device.
Some signs that your fan and heat sink may be faulty include audible humming, rattling, or overheating. Before attempting to replace the fan and heat sink, see if you can troubleshoot any fan and heat sink issues. Always clean the thermal paste when separating the heat sink and CPU and reapply fresh paste before reassembling.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Qué necesitas
Place the laptop so that the bottom is facing upwards.
Slide the latch on the left side of the battery to the left until it clicks in place.
Loosen the eight captive screws in the bottom cover using a Phillips #1 screwdriver.
Insert the flat end of a spudger in between the bottom cover and the rest of the laptop, starting in the lower left corner.
Pry the lower left corner of the bottom cover up by a few millimeters.
Slide the spudger along the bottom of the laptop to release the clips until you reach the lower right corner.
Use a pair of blunt nose tweezers to pull the white fan connector out of its socket on the motherboard.
