Introducción
Use this guide to replace the coin cell battery in your Lenovo ThinkPad T460.
A coin cell battery, also called a CMOS battery, provides power to the BIOS firmware (contained on the motherboard) which is responsible for remembering specific information such as the computer’s date, time, and BIOS settings when the laptop is turned off.
When the coin cell battery fails, an error message will appear when you power on your laptop.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Qué necesitas
Place the laptop so that the bottom is facing upwards.
Slide the latch on the left side of the battery to the left until it clicks in place.
Loosen the eight captive screws in the bottom cover using a Phillips #1 screwdriver.
Insert the flat end of a spudger in between the bottom cover and the rest of the laptop, starting in the lower left corner.
Pry the lower left corner of the bottom cover up by a few millimeters.
Slide the spudger along the bottom of the laptop to release the clips until you reach the lower right corner.
Use a pair of blunt nose tweezers to pull the white connector out of its socket.
