Saltar al contenido principal
Lenovo ThinkPad L390 Battery Replacement
Qué necesitas
  1. Lenovo ThinkPad L390 Battery Replacement, Lower Case: paso 1, imagen 1 de 2 Lenovo ThinkPad L390 Battery Replacement, Lower Case: paso 1, imagen 2 de 2
    • Before you begin, discharge your laptop battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured. Lay the device down with the lower case facing up.
    • Power off your laptop and disconnect the charger and any peripheries before beginning disassembly.
    • Unscrew the nine 5 mm Phillips #00 screws that secure the lower case.
  2. Lenovo ThinkPad L390 Battery Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad L390 Battery Replacement: paso 2, imagen 2 de 2
    • Insert an opening tool in the gap between the lower case and the chassis.
    • Pry around the entire perimeter of the lower case until it fully releases.
    • Lift the lower case up and off.
  3. Lenovo ThinkPad L390 Battery Replacement, Lenovo ThinkPad L390 Battery Disconnection: paso 3, imagen 1 de 1
    • Use your fingernails or two opening tools to gently "walk" the battery connector directly out of its socket.
    • Do not pull on the wires.
  4. Lenovo ThinkPad L390 Battery Replacement, Battery: paso 4, imagen 1 de 1
    • Remove the five 5 mm Phillips #00 screws that secure the battery.
    • The screws will be marked with an arrow labeled M2xL4 on the battery.
  5. Lenovo ThinkPad L390 Battery Replacement: paso 5, imagen 1 de 2 Lenovo ThinkPad L390 Battery Replacement: paso 5, imagen 2 de 2
    • Lift the battery up and out of the chassis.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 36
Todo El Tiempo: 172
