Saltar al contenido principal
Lenovo Legion 5 17ACH6H Left SSD Replacement
Qué necesitas
  1. Lenovo Legion 5 17ACH6H Left SSD Replacement, Back cover removal: paso 1, imagen 1 de 2 Lenovo Legion 5 17ACH6H Left SSD Replacement, Back cover removal: paso 1, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the following ten screws securing the back cover to the frame:
    • Six 12.8 mm PH1 screws
    • Four 4.6 mm PH1 screws
  2. Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the front clips: paso 2, imagen 1 de 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the front clips: paso 2, imagen 2 de 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the front clips: paso 2, imagen 3 de 3
    • Insert the rounded edge of an opening pick between the back cover and the frame in the lower right corner.
    • Angle the pick to about 45˚.
  3. Lenovo Legion 5 17ACH6H Left SSD Replacement: paso 3, imagen 1 de 3 Lenovo Legion 5 17ACH6H Left SSD Replacement: paso 3, imagen 2 de 3 Lenovo Legion 5 17ACH6H Left SSD Replacement: paso 3, imagen 3 de 3
    • Slide the pick along the front edge to release the clips securing the back cover to the frame.
  4. Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the right clips: paso 4, imagen 1 de 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the right clips: paso 4, imagen 2 de 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the right clips: paso 4, imagen 3 de 3
    • Insert the edge of an opening pick between the back cover and the frame on the right edge.
    • Angle the pick to about 30˚ and slide down the left edge to release the clips.
  5. Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the left clips: paso 5, imagen 1 de 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the left clips: paso 5, imagen 2 de 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the left clips: paso 5, imagen 3 de 3
    • Repeat the same procedure on the left edge to release the clips.
  6. Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the right vent clips: paso 6, imagen 1 de 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the right vent clips: paso 6, imagen 2 de 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the right vent clips: paso 6, imagen 3 de 3
    • Slide the opening pick between the frame and the plastic vents on the right side near the USB-A port.
    • Rotate the pick so that it is positioned on top of the plastic vents.
    • If the pick is difficult to insert, position the laptop vertically to reduce the weight on the back cover.
  7. Lenovo Legion 5 17ACH6H Left SSD Replacement: paso 7, imagen 1 de 2 Lenovo Legion 5 17ACH6H Left SSD Replacement: paso 7, imagen 2 de 2
    • Push the pick between the frame and plastic vents.
    • Slide the pick along the top edge of the plastic vents to release the clips.
  8. Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the left vent clips: paso 8, imagen 1 de 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the left vent clips: paso 8, imagen 2 de 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Release the left vent clips: paso 8, imagen 3 de 3
    • Slide the opening pick between the frame and the plastic vents on the left side near the USB-C port.
  9. Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the back cover: paso 9, imagen 1 de 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the back cover: paso 9, imagen 2 de 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the back cover: paso 9, imagen 3 de 3
    • Lift the back cover up and remove it from the chassis.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  10. Lenovo Legion 5 17ACH6H Left SSD Replacement, Disconnect the battery: paso 10, imagen 1 de 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Disconnect the battery: paso 10, imagen 2 de 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Disconnect the battery: paso 10, imagen 3 de 3
    • Use the pointed end of a spudger to push each side of the battery connector to loosen it.
  11. Lenovo Legion 5 17ACH6H Left SSD Replacement: paso 11, imagen 1 de 2 Lenovo Legion 5 17ACH6H Left SSD Replacement: paso 11, imagen 2 de 2
    • Use the flat end of a spudger to push out and disconnect battery cable.
  12. Lenovo Legion 5 17ACH6H Left SSD Replacement, Left SSD removal: paso 12, imagen 1 de 2 Lenovo Legion 5 17ACH6H Left SSD Replacement, Left SSD removal: paso 12, imagen 2 de 2
    • Use a Phillips screwdriver to remove the four screws securing the left SSD shield to the motherboard:
    • Three 3.3 mm PH1 screws.
    • One 5 mm PH00 screw.
    • During reassembly, make sure the two holes on the left side of the shield align with the posts on the chassis.
  13. Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the SSD shield: paso 13, imagen 1 de 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the SSD shield: paso 13, imagen 2 de 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the SSD shield: paso 13, imagen 3 de 3
    • Grab the SSD shield and lift up to remove it.
  14. Lenovo Legion 5 17ACH6H Left SSD Replacement: paso 14, imagen 1 de 2 Lenovo Legion 5 17ACH6H Left SSD Replacement: paso 14, imagen 2 de 2
    • Use a Phillips screwdriver to remove the 2.8 mm PH1 screw securing the SSD to the motherboard.
    • The SSD will spring up to about 30˚ when the screw is removed.
  15. Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the left SSD: paso 15, imagen 1 de 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the left SSD: paso 15, imagen 2 de 3 Lenovo Legion 5 17ACH6H Left SSD Replacement, Remove the left SSD: paso 15, imagen 3 de 3
    • Grip the edges of the SSD near the screw indent.
    • Gently pull to remove the SSD.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo Legion Answers community for help.
Chayton Ritter
Miembro Desde 08/21/20
22,506 Reputación
105 Guías creadas
Equipo
Guide Team Miembro de Guide Team
Staff
9 Miembros
11,364 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 37
Ultimos 30 días: 74
Todo El Tiempo: 3,655
