Saltar al contenido principal
Left Joy-Con Joystick Replacement
Qué necesitas
Resumen del Video
  1. Left Joy-Con Joystick Replacement, Left Joystick: paso 1, imagen 1 de 1
    Herramienta utilizada en este paso:
    Magnetic Project Mat
    $19.95
    Comprar
    • Remove the four Tri-Point Y00 screws from the back panel of the Joy-Con.
    • These screws are each 6.2 mm long, but it's still a good idea to keep them organized and make sure they go back in their proper places!
  2. Left Joy-Con Joystick Replacement: paso 2, imagen 1 de 3 Left Joy-Con Joystick Replacement: paso 2, imagen 2 de 3 Left Joy-Con Joystick Replacement: paso 2, imagen 3 de 3
    • Insert an opening pick into the seam at the bottom edge of the controller (opposite the L and ZL buttons).
    • Slowly slide the flat edge of your opening pick up the side of the Joy-Con.
    • Be careful not to slide the opening pick too far inside the Joy-Con. This may damage the inner components. The back panel loosens fairly easily, so not much pressure is needed.
  3. Left Joy-Con Joystick Replacement: paso 3, imagen 1 de 2 Left Joy-Con Joystick Replacement: paso 3, imagen 2 de 2
    • With the charging rail facing away from you, open the the Joy-Con like a book.
    • Don’t try to fully remove the back panel yet. There are still two cables connecting the charging rail to the motherboard.
  4. Left Joy-Con Joystick Replacement: paso 4, imagen 1 de 2 Left Joy-Con Joystick Replacement: paso 4, imagen 2 de 2
    • Use a spudger to gently pry the battery connector straight up from its socket on the motherboard. This will keep the Joy-Con from powering on during the repair.
    • Be very careful as you pry up the connector—if it doesn't come up with the spudger, try gently pulling the cables straight up from the board to disconnect it.
    • During reassembly, press the connector straight down into its socket on the board to reconnect the battery.
  5. Left Joy-Con Joystick Replacement: paso 5, imagen 1 de 3 Left Joy-Con Joystick Replacement: paso 5, imagen 2 de 3 Left Joy-Con Joystick Replacement: paso 5, imagen 3 de 3
    • Insert an opening pick between the battery and the Joy-Con housing.
    • Gently pry out the battery, which is lightly taped in place.
    • Be careful not to deform or puncture the battery—it can catch fire or explode if damaged.
  6. Left Joy-Con Joystick Replacement: paso 6, imagen 1 de 1
    • Remove the three 3.5 mm golden Phillips #00 screws from the midframe.
    • Do not attempt to remove the midframe yet. There is a fragile cable that still connects the ZL button on the midframe to the motherboard underneath.
  7. Left Joy-Con Joystick Replacement: paso 7, imagen 1 de 1
    • Carefully flip the midframe over, away from the motherboard, as if you were turning the page of a book.
    • Do your best not to stress the thin ribbon cable attached to the ZL button during this step.
  8. Left Joy-Con Joystick Replacement: paso 8, imagen 1 de 3 Left Joy-Con Joystick Replacement: paso 8, imagen 2 de 3 Left Joy-Con Joystick Replacement: paso 8, imagen 3 de 3
    • The ZL button cable is locked in place by a small ZIF connector on the motherboard. Use tweezers or a spudger to flip up the ZIF connector lock opposite the cable.
    • Use tweezers to gently pull the ZL button flex cable out of the ZIF connector socket. The midframe is now disconnected and can be removed.
  9. Left Joy-Con Joystick Replacement: paso 9, imagen 1 de 3 Left Joy-Con Joystick Replacement: paso 9, imagen 2 de 3 Left Joy-Con Joystick Replacement: paso 9, imagen 3 de 3
    • The ribbon cable connecting the minus button of the Joy-Con to the motherboard runs over the back of the joystick. It is possible to remove the joystick without disconnecting this cable, but it's much easier to do so when it is disconnected and out of the way.
    • Unlock the minus button’s ZIF connector and disconnect the cable.
  10. Left Joy-Con Joystick Replacement: paso 10, imagen 1 de 3 Left Joy-Con Joystick Replacement: paso 10, imagen 2 de 3 Left Joy-Con Joystick Replacement: paso 10, imagen 3 de 3
    • Finally, the joystick is locked into place by one last ZIF connector. Carefully flip the ZIF lock upward and disconnect the cable.
  11. Left Joy-Con Joystick Replacement: paso 11, imagen 1 de 1
    • Remove the two 3.5 mm Phillips #00 screws from the joystick.
  12. Left Joy-Con Joystick Replacement: paso 12, imagen 1 de 2 Left Joy-Con Joystick Replacement: paso 12, imagen 2 de 2
    • Carefully remove the joystick from its housing.
    • There is a thin black gasket around the hole where the joystick pokes through the Joy-Con. Do your best not to disturb this gasket as you remove the joystick!
    • Once the Joy-Con is fully reassembled, connect it to your Nintendo Switch and calibrate the new joystick. Additionally, you may need to power cycle your Switch by holding down the power button for 10-15 seconds until it turns off, then turning it back on.
Conclusión
922 personas más completaron esta guía.
Taylor Dixon
Miembro Desde 06/26/18
67,116 Reputación
94 Guías creadas
150 comentarios
Thx This really helped
Stev Steve - Contestar
Thanks Kyler - I just replaced 4 joysticks and they’re all working perfectly.
One final step to remember to go in and calibrate the controller.
David K - Contestar
You're welcome I'm glad I could assist you in your repairs!
Kyler Saunders -
Thanks. This was just the right amount of info and now my left stick drift is gone….for now.
Jason Hoover - Contestar
I would recommend at least once a month take a can of compressed air and spray the joystick internals to clear it of any dust or debris.
Nick Mensch -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 217
Ultimos 7 días: 1,711
Ultimos 30 días: 9,351
Todo El Tiempo: 635,834
