Saltar al contenido principal
LG G3 Battery Replacement
Qué necesitas
  1. LG G3 Battery Replacement, Back Cover: paso 1, imagen 1 de 2 LG G3 Battery Replacement, Back Cover: paso 1, imagen 2 de 2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Battery Replacement: paso 2, imagen 1 de 2 LG G3 Battery Replacement: paso 2, imagen 2 de 2
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. LG G3 Battery Replacement, Battery: paso 3, imagen 1 de 2 LG G3 Battery Replacement, Battery: paso 3, imagen 2 de 2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
  4. LG G3 Battery Replacement: paso 4, imagen 1 de 2 LG G3 Battery Replacement: paso 4, imagen 2 de 2
    • Lift the battery out of its recess and remove it.
Conclusión
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
21 personas más completaron esta guía.
Dominik Schnabelrauch
Miembro Desde 11/23/16
204,379 Reputación
682 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,299 Guías creadas
Un comentario
Thank you very much!
ItayDigital - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 38
Todo El Tiempo: 17,595
